12-08-2016, 08:21 AM | #1 |
Drives: Yes Join Date: May 2009
Borla S-Type Axle Back 11924 for Gen6 Camaro SS with Dual Mode Exhaust
Borla S-Type Axle Back 11924 for 2016 2018 Gen6 Camaro SS with Dual Mode Exhaust $1,589.99 FREE SHIPPING!
http://www.pfyc.com/BO11924.html Borla designs their exhaust products to ease the stranglehold your stock exhaust system has on your vehicle's engine. Borla's patented technology opens the way for escaping gasses, and maximum exhaust flow equals improved performance. This translates into more power and torque when you plant your foot, along with increased fuel economy at cruising speeds. Borla builds its exhaust systems from aircraft-grade T-304 stainless steel, so they're lighter, stronger, and last far longer than factory exhausts - all with easy bolt-on installation. Extensive research determines which tube size will get the most performance from your car or truck. Smooth mandrel bends and efficient design give the exhaust a mellow rumble while keeping most of the sound behind the exhaust tips. This means you won't get unwanted droning noises in the cockpit while cruising. Every Borla exhaust system gives you precision fit with motorsport-inspired styling, all backed by a million-mile warranty against defects in material or workmanship. This high-performance replacement exhaust system includes all parts and hardware required for installation (some factory original parts may be re-used). http://www.pfyc.com/BO11924.html Application 2016 2017 Camaro SS 6.2L with Dual Mode Exhaust Last edited by PFYC; 06-17-2019 at 02:41 PM. |
Thread Tools | |
