08-07-2018, 04:37 PM | #113 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
If your factory alignment is anywhere near spec, it would be a miracle, and possibly the first on this forum to witness it.
The Performance Supplement recommended Track alignment is transformative, like a good alignment always is. Even then, it's not enough front camber for regular track work, but it is a solid base-line.
08-07-2018, 04:45 PM | #114 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
08-08-2018, 11:48 PM | #115 | |
Drives: Bmw f80 m3 Join Date: Jul 2018
08-08-2018, 11:54 PM | #116 | |
Drives: 2023 2SS, 2018 1SS 1LE, 1993 Z/28 Join Date: Jun 2018
08-09-2018, 06:16 AM | #117 | |
Drives: '18 1SS 1LE Join Date: Sep 2017
The main change is more negative camber, which will only increase wear the inside of the tire over extended street driving. Car will behave normal. The other change is a more precise toe adjustment which is closer to zero than street. Street has a little more toe in which helps the car go straight, where Track has less toe in that allows a little more wander and quicker turn in during a corner.
'18 1SS 1LE Black, PDR
08-09-2018, 09:06 AM | #118 | |
It is also important to realize the power delivery will vary dependent on drive mode chosen: by design. And those are rather complex given the number of choices available hence worthy of familiarization before casting a verdict Another info tid bit: GM fully warrants these cars stock (and Vettes) for track duty with zero questions asked. |
08-09-2018, 09:59 AM | #119 |
Hot Dog
Not whatsoever. The car will have improved steering feel, minimized rear-end side-stepping over big bumps, and overall improved predictability over the haphazard alignment from the factory.
08-09-2018, 11:00 AM | #120 | |
Thread Tools | |
