#71 |
![]() Drives: 1SS Summit White 6 speed Join Date: Jul 2017
Ted,
Any updates on how this Camaro has held up ?
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
#72 |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
That was my shop car, it was returned to stock and traded in on my 2018 ZL1 1LE,
We have built/tuned/sold this package 100s more like it with no issues. Ted.
www.jannettyracing.com
#73 |
![]() Drives: 21 Lt1 Join Date: Dec 2016
So in the end with the LPE HPFP and LT4 injectors, Lt1 stock cam was it confirmed that you could run E80 at 7-9 psi? I’m running a P1-X so it’s probably quite different on fuel consumption over a PD.
I have the +30 I can put in with the LPE but if I can’t support e80 with stock Lt1 cam then idk if it would be worth it or not…. |
#74 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1SS NFG A8 Join Date: Aug 2017
Put the car in 6th gear, use hard street tires, and SAE correction, it probably would have made 615-620whp. Some dyno shops use STD correction instead of SAE to off set the difference of using a lower gear to dyno. 1:1 gear makes the most power but many dyno shops will not use 1:1 due to the high speeds. STD correction dynos about 10-15whp higher then SAE. 6th gear dynos about 15-20whp higher then 5th for A8. Same for 7th and 6th on A10. Drag radials dyno 10-15whp lower then street tires. I only mention this because you seem hyper focused on dyno numbers. Far as performance times. VIA dragy I went 10.8 @ 132 on this setup. Then I dropped from a 3.5 to 3.25 pulley, Switched to big gulp from standard RF, 103mm tb, lowered E down to E40, and have been a best of 10.5 @ 136 with a soft 1.8 60ft...still running 20" wheels.
2016 NFG 1SS A8
#75 |
Thanks King.
Yeah I’m gonna get it tuned with the LT4 stuff I have in the car now on 93 and tuner should have an idea where I stand on fuel etc. I can always add the Lpe and +30 at that time. Only reason I reference the dyno numbers is because that seems like what everyone uses as a reference when talking about e% content. If the car made 575 or 650 I wouldn’t care. I care more about being able to run pump e85 in the end. I’m sure whatever it makes hp wise will be a night and day difference over FBO and it will be a huge difference. |
Thread Tools | |
