#29 | |
![]() Drives: 2016 2SS Join Date: Aug 2015
#30 |
![]() Drives: 2016 2ss garnet red soon Join Date: Aug 2015
Thanks Sledge. Installed mine last night. Great video.
2SS Black/Adrenaline Red
#31 |
![]() Drives: 2010 1SS Join Date: Apr 2013
Just did the install on the shop car for the LED RS reverse lamps. Check it out, works great. About a 30 minute install
http://www.gen5diy.com/image/data/Car Manufacturer/Chevrolet/Camaro G6/Install PDFs/Gen6taillightremoval.pdf http://www.gen5diy.com/image/data/Car Manufacturer/Chevrolet/Camaro G6/Install PDFs/Gen6reverselampharness.pdf |
#32 |
![]() ![]() Drives: 2017 Corvette Grand Sport Join Date: Aug 2009
would 7443 leds work? see no reason why not, but thought id ask?
#33 |
![]() Drives: 2021 Shadow Grey ZL1M6 Join Date: May 2012
Can you post pictures of your install? I cant picture in my head thow this would work
2021 ZL1M6, Shadow Grey
#34 |
![]() Drives: 2018 Hot Wheels 2LT Join Date: Jul 2010
It is not too difficult. IMO the hardest part was the LED bulbs I got were somewhat long and where the light socket is located is quite limited room to work with so mine BARELY fit. You only need 1 harness to be installed on 1 side only and that will take care of both sides. So the harness on 1 side plugs into the factory harness (where you would normally put in the bulb) and then you new LED bulb plugs into the new harness which you will push into the socket. The other side all you do is replace your factory bulb with an led bulb. The harness on the 1 side will prevent the "afterglow" effect. That's it.
#35 |
Oh I got that part. I was asking about the Phillips canceler
Sent from my SM-G920T using Tapatalk
#36 |
I got the philips canceller and it looked much easier then modifying the adapter with a dremel. It just tapped the wires really easily. Here's the links to the canceller and lights I used. Super simple install.
http://www.amazon.com/gp/product/B00...ilpage_o04_s00 http://www.amazon.com/gp/product/B00...ilpage_o04_s00
Adrenaline Red
20" 5 Spoke Black Black Side Spear Dual Mode Exhaust MRC Splash Guards 1G1FG1R74G0124089 |
#37 | |
#38 |
You only need one. I put it on the driver's side but I don't think it matters.
Adrenaline Red
#39 | |
I can verify it works to prevent the afterglow effect |
#40 |
![]() Drives: 2016 camaro ss Join Date: Oct 2015
Great write up sludge great video just ordered the parts you suggested thank you.
#41 |
I had to use 1 on each side, had a few packs of 2 resistor lying around 25w. tried 3 different ones on the drivers side and in the end, just put one on the other side as well and everything was good. would not work with only one on mine. weird. gotta do the front next.
#42 | ||
![]() Drives: 2SS, Mosaic Black, Ordered Join Date: Dec 2015
Thanks for making this video. I changed my reverse lights today and used your video for reference. I got lazy and used the harness and lights from Gen5DIY. Other then having a hard time getting the OEM wiring harness apart, this went easy.
2SS, Mosiac Black, Adrenaline Red, A8, MRC, NPP, Sunroof, Nav, Silver split spoke
Ordered 12/28/15 1100 1/11/16 2000 1/26/16 2500 1/27/16 3000 1/28/16 3300 1/29/16 TPW 2/15/16 3400 2/4/16 3800 2/15-16 BUILT!!! 4300 2/17 4200 2/23 4800 2/26 6000 3/5/16!!! 2015 Silverado LTZ 2011 Escalade 2006 Honda Accord 1988 IROC Z Camaro (sort of dead) |
Thread Tools | |
