05-11-2023, 01:29 PM | #15 | |
05-11-2023, 10:29 PM | #16 |
Driver for Hire
Interesting! I found my 2018 on the lot, ordered my 2022.
Luan Zeqollari
2022 Camaro SS 1LE M6 - Wild Cherry Tintcoat - Delivered 9/20/21 2018 Camaro SS 1LE - Hyper Blue Metallic - RIP 6/6/20 YouTube Channel |
10-14-2023, 03:42 PM | #17 |
Drives: 2022 ZLE 6M Join Date: Jun 2021
FYI - There is a Kit for the rear:
GM 85523690 DEFLECTOR KIT-FRT BRK CLG https://www.gmpartsgiant.com/parts/g...-85523690.html |
10-16-2023, 08:55 AM | #18 | |
Driver for Hire
Luan Zeqollari
12-13-2023, 03:36 PM | #19 |
I finally received my Blackwing Brake Cooling Ducts after 3 months of order cancellation and reordering, what a size difference from stock ZL1. I don’t seem to have much of a dust shield so that’s good
I must be blind or stunned? For the love of God, I can’t figure out how the rear cooler deflectors fit. #84946131,32 edit: Ok figured it out, I need to drill holes and make spacers Last edited by CalgaryZL1; 12-13-2023 at 04:58 PM. |
12-13-2023, 06:54 PM | #20 | |
Driver for Hire
85004630 - Rear Trailing Arm (FE4/FEA) You shouldn’t need to drill any holes. Should already be there. There are part numbers for the spacers, too.
Luan Zeqollari
2022 Camaro SS 1LE M6 - Wild Cherry Tintcoat - Delivered 9/20/21 2018 Camaro SS 1LE - Hyper Blue Metallic - RIP 6/6/20 YouTube Channel Last edited by FollowMyLine; 03-04-2024 at 06:59 AM. |
12-14-2023, 04:42 AM | #21 |
Reading other threads, apparently model year 2022 and up have the holes, is my understanding. I didn’t realize there was a rear kit, so I ended up ordering the two individual part numbers and I don’t know the part number for the spacer.
12-14-2023, 09:51 AM | #22 | ||
Instagram: Sangstah
Here's a step by step video tutorial for the rear. I checked my 19 1LE and the holes weren't there on mine either. You will have to drill if not.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
12-14-2023, 01:07 PM | #23 |
Thanks for the info! I just decided to order the upgraded arms with the holes, they are only $66 US a pair. With the apparent flex of these arms, I want to eliminate any notch affect from drilling a hole with the drill bit.
01-31-2024, 03:49 PM | #24 |
Drives: 2022 Camaro 1SS 1LE Join Date: Sep 2022
I have holes in rear control arms on my 2022 SS 1LE and half-size dust shields in the rear.
I've decided to go with 85523690 kit for the rear instead of buying ducts and hardware separately, and ordered Blackwing ducts and mini dust shields. Appeared to be less then $100 in total, and I hope I will get the delivery soon
2022 Camaro 1SS 1LE Rapid Blue 6MT
Looking for traction on wet pavement in Seattle. |
01-31-2024, 05:30 PM | #25 |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Damn the front hang low...
2022 M6 ZLE: Katech Standard Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation Kit
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC + RF BG Coated AR Headers + GESI UHO Cats + V Bands + AWE Touring + Magnaflow Center X + MSD Coils + Banks iDash + JMS Booster ALL the BMR Read End Goodies + BMR Motor Mounts + JRE Terminator Cam Package + FIC 30 + DMS Front HX + Fender Tank GMS High Flow Impact Bar + GMS Stage II Oil Cooler + GMS Stage III HX System = 770rwhp 815rwtq @E55 13.5psi |
03-04-2024, 04:16 AM | #26 |
Good info, thanks
03-04-2024, 06:55 AM | #27 |
Driver for Hire
Updated the first post with more part numbers:
23385146 - Front Left Mini Dust Shield 23385147 - Front Right Mini Dust Shield 85536980 - Front Right BW Brake Cooler 85536981 - Front Left BW Brake Cooler 84946132 - Rear Right BW Brake Cooler 84946131 - Rear Left BW Brake Cooler 84946133 - Rear Thread Insert for Screws 85004630 - Rear Trailing Arm (FE4/FEA) 85523690 - Rear Cooling Kit 11548166 - Screws x6
Luan Zeqollari
03-04-2024, 09:01 AM | #28 |
Drives: '22 2SS 1LE Join Date: Nov 2023
For SS 1LE guys you definitely need smaller front dust shields or have to cut the OE. The stock ones block the ducts.
Thread Tools | |
