12-24-2022, 09:27 AM | #15 |
Detroit Speed Engineering has a nice piece as well.
https://www.detroitspeed.com/product...parts/011204DS
Orange Krush II
08-01-2023, 05:53 PM | #16 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
Not the best pictures but put the loop in with DS today. Very easy install the loop itself was tight a fit over DS. I had the heat shield on with shaftband it fit fine but had to take it back off for the safety loop.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
08-01-2023, 07:44 PM | #17 |
Very nice. That looks cool.
08-02-2023, 07:09 PM | #18 |
So I took the car for a ride, had a vibration I didn't notice but the loop extension bolt heads were resting on exhaust all 4. I took all the washers off and it was still hitting. I then moved the extension to the top side I now have a little clearance. Hopefully it's enough. Even with out extension it would still hit.
08-04-2023, 07:19 AM | #19 |
None of you guys had clearance issues? I had it below because that is what it looked like you guys were doing, I am hoping the little bit of clearance I have now will be okay, I will probably try it out this Sunday.
08-04-2023, 12:33 PM | #20 | |
08-04-2023, 01:01 PM | #21 |
It was resting on the pipe so it was random.
08-04-2023, 01:18 PM | #22 | |
I didnt have that issue.. I will take a look here in a little bit when I go out to work on it. Roy
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
08-05-2023, 05:26 AM | #23 |
Mine is on top and have the bolts coming in from the top. Seems like I remember having to swap things around when I first put it in.
08-05-2023, 06:27 AM | #24 |
Thanks for checking you appear to have more clearance then I do . I think in your the pictures on your install you had it the other way. Hopefully it's okay or I'll have to remove it I don't see any way to get any more clearance.
08-05-2023, 06:32 AM | #25 | |
I will update the post. Sorry about that. Roy
Thread Tools | |
