10-31-2022, 09:43 AM | #15 |
Drives: 2020 ZL1 A10; Shadow Gray Metallic Join Date: Sep 2020
I'm curious as to why you think it's the canards that are planting it and not the factory 1LE lip spoiler.
10-31-2022, 10:08 AM | #16 | |
Drives: Garnet Red / ZL1 1LE Join Date: Apr 2016
The front splitter and canards work in tandem with the rear spoiler. See video below -
#SAVETHEMANUALS
10-31-2022, 09:44 PM | #17 | ||
Drives: 2020 ZL1 1LE Join Date: Sep 2012
Another article here.
11-01-2022, 12:15 PM | #18 |
Drives: Zl1 1le Join Date: Apr 2018
My Canard Story: I was instructing a student at Pitt Race in Cayman based race car. At 90 mph on the back straight the car started to swerve left and right as if the driver was trying "scrub his tires". He was not. After the second occurrence - we pulled into the garages, jacked up the car, and went over every piece of the suspension. No issues found. As we were about to leave the garage I noticed the passenger side dive plate was missing. I told him take off the driver side dive plate and see what happened. No more swerving. My take away - those diveplates/canards kick in significantly above 80 mph - in terms of both drag and downforce.
11-01-2022, 01:28 PM | #19 |
Shadow Gray '19 ZLE M6
What show is this clip from? Very cool. I'd like to see the whole episode.
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
11-01-2022, 02:32 PM | #20 |
It's on Prime Video - /Drive - Season 4. Episode 1. They have a special segment in that episode about the ZL1/1LE.
#SAVETHEMANUALS
11-01-2022, 04:53 PM | #21 |
Speaking of canards, where can I buy the driver's side canard at a decent price
'20 ZL1LE A10.
LME 390, E2650, FBO. 1116/967. 15" conversion/Weld/MT ET Street R 325/50R15. 100 octane: 1.35/9.25/151 at 3500 ft. (only one pass so far). 100% meth/100 octane: Alky Twin 10+10 MAF; No dyno or ET. |
11-01-2022, 05:20 PM | #22 | |
11-01-2022, 05:32 PM | #23 | |
Drives: E92 BMW M3 Join Date: Oct 2012
J-Rod Built and Matt@FSP Tuned |
11-01-2022, 05:34 PM | #24 | |
Drives: 2019 ZL1 1LE Join Date: Oct 2019
Also, I don't see you needing to change out fronts for every session. I often run my own scrubs, but have run takeoffs a few times. If you get your alignment right you should be able to get at least 1 day out of them no problem. In terms of DF numbers from the canards, they are less of a downforce effect than they are cutting lift by directing air around the wheel wheels and eventually towards the back of the car and will make a difference in the high speed balance of the car.
2019 ZL1 1LE A10
AP Racing Brakes - MCS/Vorshlag 2WR - MFR Engineering Diffusor + Flat Floor - C&R Oil Cooler + Heat Exchanger - Piper Motorsport Cage - Anderson Carbon Doors + Trunk |
11-01-2022, 09:30 PM | #25 | |
11-01-2022, 09:45 PM | #26 | |
Yeah I was going to run Pirelli DH 305/660 18 F and 325/680 18 R, going to do the strut grind. That's a good point, though. I was always comparing to ZLE measurements. The stock ZL1 heights are 26.7" F 27.2R compared to 26" F 26.8" R on the takeoffs. Looks like I should run 305/680 F. Not sure what size up is on the rears. Last edited by Slurpee; 11-01-2022 at 09:50 PM. Reason: grammar |
11-02-2022, 12:19 PM | #27 | |
On the alignment side, I'd say the factory track alignment is a good place to start. If you can, try and get some tire temps and adjust from there. These cars don't need crazy amounts of camber. I've run those sizes in Pirelli's, you should be fine. There's an old thread in here about the percentage difference in height FR/R and I would say that's the most important thing when it comes to choosing the takeoffs you want to run. But if you don't use the PTM modes, don't worry about it.
2019 ZL1 1LE A10
11-02-2022, 12:39 PM | #28 | |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
Tags |
zl1, zl1 1le |
Thread Tools | |
