#15 | ||
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
#16 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
I spoke to the guy tuning my car yesterday and we tentatively have Oct 1st as a flex fuel install date. He is pretty confident on e40 and possibly e50. I have not done any high side mods yet so it will be interesting.
I also questioned him on the higher than norm Lambda and he pretty much said he has tuned many leaner than most without issue. Just cause others run them on the rich side doesn't mean he is wrong running them leaner. Basically he said it works and the motors are still happy. If I can get e40 out of it I will be happy and call it a day!
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
#17 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '20 ZLE Join Date: Jun 2020
I have never flashed my 91 oct. tune and always run the 100 fuel/tune.
Our plan, Chapman (CAP) and me, is to leave the pullies as they are now and dyno/remote tune the Stage X/100 build to get it producing as much power as it safely can on 100, and see where we are with high side fueling. Then start to figure out what all we will have to do to produce more power with E. I'm not an E guy, but from what you're saying, it's sounding sketchy whether I can use Bandimere's pure E85 (four miles from my house @$4.00/gal.). My local station is $2.83. Bandimere's 100 u/l oct. is $8.00! Quote:
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. 1116/967. 1.35/9.25/151 at 3500 ft. (only one pass) 15" conversion/MT ET Street R 325/50R15. Last edited by JSH; 09-22-2021 at 07:57 AM. |
#18 |
I've said from the outset that, if my Kong build works, great, but if it doesn't, a Maggie is in my future.
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. 1116/967. 1.35/9.25/151 at 3500 ft. (only one pass) 15" conversion/MT ET Street R 325/50R15. |
#19 |
![]() ![]() ![]() ![]() Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
JSH,
I’m at the same altitude with just bolt on mods, including a JMS pump Booster and I’m flex tuned to run up to e70. Remember when these guys estimate how much ethanol content you can run, you can run more due to our altitude (10 pts higher with my mods). I’d be at e60 max at sea level. The biggest gains in running ethanol are realized when you are running e30ish to e50ish. My opinion is that it would be worth it for you to try the flex fuel kit and let your tuner see what you can safely run at our altitude. |
#20 | |
'20 ZL1 1LE A10.
#21 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1SS NFG A8 Join Date: Aug 2017
High altitude means your making less power which is allowing you to run more E.
The Dyno SAE/STD correction factor is misleading in this situation. Compare uncorrected vs corrected numbers and you will see.
2016 NFG 1SS A8
#22 | |
I've got an email from DynoJet saying their CF is not designed or intended to accurately correct, in my case, from Hennessey/Houston to Denver, which can be a DA difference of ~8000 ft. They said it is designed to correct between different pulls in the same shop on the same car on the same dyno. They speculated that a 6000 ft difference might be a 30% correction! This seems too high as we generally use a 20% CF. Anyway, all of this appears to be old news to my builder/tuner, Cody Chapman, who plans to do some yet to be determined % of Eth.
'20 ZL1 1LE A10.
#23 | |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
Thinking about adding the FIC Injectors, LPE pump and a good low side system myself. Would like to run E50, but my cam lobe is only 32%. Do you think this could work?
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel. Elite tuning, results coming soon. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: Swisstyphoon1980 |
#24 |
He is running a 32% Cordes stage 2.
2016 NFG 1SS A8
#25 | |
![]() Drives: 2019 ZL1 Crush Join Date: Jan 2019
2019 Crush A10
E-Force 2650 670WHP 615WTQ All besides the 2650 is bone stock down to the air filter. |
#26 |
Cool, I should be ok then.
Thanks King!
2018 Camaro ZL1 A10
#27 |
They got a new dyno a few weeks ago.
'20 ZL1 1LE A10.
#28 |
![]() Drives: 19’ ZL1 A10 / 16’ C7Z M7 Join Date: Apr 2021
Thread Tools | |
