08-29-2021, 02:45 PM | #15 | |
Drives: Buick, Toyota Join Date: Aug 2021
08-29-2021, 03:02 PM | #16 |
Drives: 2018 Camaro V6/RS Join Date: Nov 2018
Those few mods made the car much more enjoyable. The extra sound from the intake and exhaust, and throttle response from the throttle body, truly make a substantial difference in overall driveability and satisfaction. For the $1500 upcharge the V6 is the way to go in my opinion.
08-29-2021, 03:58 PM | #17 | |
Drives: 22 ZL1 M6 Join Date: Oct 2018
you'll be happy with the v6 over turbo. if you were going to track it a lot, the turbo4 is awesome because of weight + more after market. the v6 will give u the sound and better experience if its a weekend toy for sure, especiallly with some mods. my friend has headers and borla on his v6 and it sounds mint
Sold: '17 m6 2SS [arctic blue]
Current: '22 m6 zl1 [vivid orange] |
08-30-2021, 06:45 AM | #18 | |
Where upstate are you? |
08-30-2021, 06:59 AM | #19 | |
Between Rochester and Buffalo. Closer to Rochester though. I did my order last week but had to send it in as a 2021 since the 2022 option wasnt on the Chevy site yet. My dealer contact said he'd change it to a 2022 since all of my options carried over and were still available. Gosh, I hope this works out and I get my car by spring. Im starting to get worried..... Where are you located? |
08-30-2021, 08:52 AM | #20 |
Drives: 2022 RS Convertible Join Date: Jul 2021
Can anyone confirm the V6 constraint is still in effect? My order for 2022 RS V6 convertible is in 3400 status. I wanted a V6 for a convertible as I think it's a sensible option, but now I'm considering if I should go with LT1. Will they let me switch the order?
Thank You. |
08-30-2021, 09:10 AM | #21 | |
Drives: 23 LT1/22 Colorado TB/69 Chevelle Join Date: Jun 2006
08-30-2021, 09:12 AM | #22 |
V6 1LE was discontinued for 2022 model year. Unfortunately, if your 2021 order never made it past 1100 status, then you're out of luck. You won't be able to order a 2022 V6 1LE.
08-30-2021, 09:43 AM | #23 | |
BLUPRINT_1LE
Drives: 2022 Rapid Blue SS 1LE Join Date: May 2017
Sorry to thread Jack, but Gearhead did you see any more constraints on colors or any other options? Thank you in advance for your help and info
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE YT: BLUPRINT_1LE ---------------------------------------------------------------- |
08-30-2021, 11:47 AM | #24 |
Yes, Unfortunately. I may just go 1LTV6 Rapid blue, manual, big break/oil cooler, RS, front lip, and Tech. Which brings me to more questions which I'll post somewhere else... but with good light weight wheels and sticky tires i hope to have similar performance to the 1le.
08-30-2021, 12:53 PM | #25 | |
Why not just ask the dealer you ordered with...? They would not be able to have an order accepted if an allocation they were given has a restraint, for example, no rapid blue. Until that is lifted the order will sit at 1100. I see you have an order number so just check what stage it's at. If it's been accepted that means your dealer didn't have constraints on what GM allocated to them
08-30-2021, 01:41 PM | #26 | |
BLUPRINT_1LE
08-30-2021, 03:58 PM | #27 | |
Got it! Constraints can differ as far as I am aware. Higher volume dealers may not have the same constraint as another. Here in Canada it's completely different as well (we get much fewer cars, but it seems to be more orderly). I think the allocations given trump any and all restrictions. If GM allows your dealer to submit it they'll have it built regardless of what they may be allowing nationally
08-30-2021, 03:59 PM | #28 |
for what it's worth, I heard there is a constraint on all ZLE as they do not have any spoilers
Thread Tools | |
