05-07-2019, 12:58 PM | #15 |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
05-07-2019, 01:10 PM | #16 | |
Drives: 2017 ZL1(Silver) - A10, Stock Join Date: Jan 2019
I then went to get my car tuned locally to see if there was an issue with throttle body not opening 100% or some other issue and car ran fine for first pull but then IATs went thru the roof and wouldnt come down and massive amount of timing pulled. I ended up having the shop put on a Cordes intercooler reservoir/tank and now I can actually see the coolant flowing if I check. This takes care of any possibly air trapped in intercooler system as well. Car went back on dyno and IATs never went above high 120s after successive dyno runs.
2017 ZL1(Silver) A10
05-07-2019, 01:40 PM | #17 |
Drives: 2016 2SS Convertible Join Date: May 2012
I think there were some TSBs for cable rubbing issues:
https://www.camaro6.com/forums/showthread.php?t=552758 I think there was a TSB for a cable rub issue on the engine too (A/C belt?) but I don't seem to be able to find it now. |
05-07-2019, 07:59 PM | #18 |
Drives: Camaro ZL1 2017 Join Date: May 2019
i may try tomorrow. some ask me to disconnect the battery for 2 hours then program will be set
05-08-2019, 07:40 PM | #19 |
guys another problem came up
fuel not normal. i drive really slowly and no more then 3500 RBM can you believe only 111 km / 30 liters of 95 octane and my GM still saying is normal |
05-08-2019, 07:49 PM | #20 |
please guys
advice me what i do. my dealer can not help me |
05-08-2019, 08:14 PM | #21 |
Who Needs to KNOW?
Try higher average speed.. 15km/hr (9mph in yankee units).. were you in a parade ?
ing for grip.
05-08-2019, 09:04 PM | #22 |
Drives: 2017 ZL1 A10 Summit White Join Date: Apr 2018
Try this. https://youtu.be/MMphi_3xgCc
05-08-2019, 10:28 PM | #23 |
95 octane? If this is the same as EU octane ratings, you need 98 at least (which may not be your only problem, but it's definitely one). Also, your average speed is very-very low, as others already mentioned. At these speeds the LT4 swallows gas in big gulps.
05-09-2019, 08:30 AM | #24 | |
Kevin
Drives: 2018 Callaway Camaro ZL1 1LE Join Date: Apr 2018
05-09-2019, 08:44 AM | #25 |
quit using shit fuel.
2016 NFG 1SS A8
05-09-2019, 03:21 PM | #26 |
@viurniel
Drives: 19 ZLE A10, 15 2SS, 90 300ZXTT Join Date: May 2016
All points to a gas issue. In your location, I would recommend going even higher than 98 as your gas rating is not reliable. To fix the current gas in your tank you can mix it with RON 105 gas (provided you trust the rating).
Also 15km/h average? Time your ride so that you are not in traffic too much. |
05-09-2019, 06:19 PM | #27 |
Just noticed he is in Saudi Arabia! My suggestion is to take it to the dealer you bought it from if in your location and get it checked.
05-10-2019, 04:38 AM | #28 |
yesterday i took it to my dealer they will check it up
aircooling system i hope it's woke up again |
Thread Tools | |
