Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 05-01-2015, 11:25 AM   #15
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
If i may, on the 2012 and up cars GM moved the frames of data around to make room for more things on the land bus and that is what you will need to fix to make it all work.
P.S good luck.
2SSRS@Gen5diy is offline   Reply With Quote
Old 05-01-2015, 12:01 PM   #16
USCAMARO14
USCAMARO14's Avatar
Drives: 2LS 2014
Thumbs up
P.S good luck.
So I can make it work. Just plug and play?
USCAMARO14 is offline   Reply With Quote
Old 05-01-2015, 12:04 PM   #17
Tmick5jr
Todd
Tmick5jr's Avatar
Drives: 2012 Camaro
P.S good luck.
so this should function perfectly fine on 2012 and up cars?
Tmick5jr is offline   Reply With Quote
Old 05-01-2015, 12:22 PM   #18
DWALEX
DWALEX's Avatar
Drives: Currently 2016-2SS, Future ZL1/Z28
P.S good luck.
any help is welcome,👍
if that is the case the new color HUD it wouldn't function
DWALEX is offline   Reply With Quote
Old 05-01-2015, 04:22 PM   #19
Squishy
Squishy's Avatar
Drives: 2016 camaro 1SS
Whats the issue with the rpm?
2016 BLK Camaro 1SS/LT1 M6:
NPP | black front/rear bowtie | Blacked out taillights
2011 IOM Camaro 1SS/RS LS3:
Stainless works 1 7/8" LT headers w/ Offroad pipes | TSP Cam 235/239 on a 112 | Powerbound 25% UD Pulley
Roto-Fab Cold Air Intake | SW Retro Chambered Catback Exhaust | VMax Ported TB | Hurst Short Throw Shifter
Trunnion upgrade | LSA Oil Pump | BMR 1.25 Spings | R1 Concept d/s Rotors
Tuned by Lashway Motorsports - 501 Hp 430 ft-lb
Squishy is offline   Reply With Quote
Old 05-01-2015, 06:01 PM   #20
DWALEX
DWALEX's Avatar
I don't know in this point
Old 05-02-2015, 09:40 AM   #21
moose517
moose517's Avatar
Drives: 2013 1SS
this is something i've wanted to do myself, i've got a 2013 and was curious how plug and play it would be to get one and just pop in and go.
moose517 is offline   Reply With Quote
Old 05-02-2015, 12:19 PM   #22
zkattac
Drives: 2011 Synergy Green 2SS Camaro
Wow, awesome job so far! Excited to see more!
zkattac is offline   Reply With Quote
Old 05-04-2015, 02:19 PM   #23
2SSRS@Gen5diy
No the HUD works on all cars, its different data frames.
Old 05-04-2015, 02:37 PM   #24
Arksine
Arksine's Avatar
Drives: 2013 2SS/RS L99
2012+ cars are compatible, they just need programming. I just ordered one from gen5diy for my 2013. PM them and they will get you set.
Arksine is offline   Reply With Quote
Old 05-04-2015, 04:45 PM   #25
DWALEX
DWALEX's Avatar
do you have it installed? I have a question!
Old 05-04-2015, 04:50 PM   #26
USCAMARO14
USCAMARO14's Avatar
Drives: 2LS 2014
Thumbs up
Does it come program already?
Old 05-04-2015, 09:23 PM   #27
Arksine
Arksine's Avatar
Not yet, just ordered it over the weekend. Expecting it to arrive in around 3 weeks.
Old 05-05-2015, 08:45 AM   #28
DWALEX
DWALEX's Avatar
As I told you in the pm the biggest problem with this cluster is that it asks for IDs frames or it is not compatible with the modules of the 2010-11 or they don't have it, I was able to disactivate this functions in the cluster (EX: steering wheel, suspension, etc.) but it is also necessary to upgrade some modules, at the moment I only need to correct a DTC CODE "U0020"
this code is set up when fewer modules are detected on the bus before the cluster can learn the other modules IDs
I'll post more info later
