![]() Drives: 2017 ZL1 Join Date: Jun 2012
Brake Caliper Makeover & Lessons Learned
Ever since I brought the ZL1 home I hated the muted color of the brake calipers. Those beautiful monsters just get lost behind the stock wheels, since the color is so close. So, my color of choice is and always will be red, so that's what I chose to go with. I had purchased the paint way back in April, but dredded taking on this task and have procrastinated up to this point (decals purchased on Ebay). I dreaded it because I know this needs to be done right in order to last. To me that meant removal of calipers, sanding, priming, painting, application of decals, and heavy clearcoat. As i get a naturally built in 7 days off work every month, I finally got a few goods days to throw at the task this week. If anyone wants to take on this task and wants it to be pro level, only tackle this if you have the time, skill, and patience. I made mistakes that and every time in hindsight it could have been easily avoided. First up. I painted the right front caliper. Paint laid down smooth, decals were applied, and clear went on. The caliper was looking great! I decided to let it cure over night before reinstalling. So I stored it in our laundry room since it's the warmest in the house. I woke up the next day feeling good about my accomplishment. I was horrified to find my beautifully painted caliper's finish marred by a stream of brake fluid that had been running out of the bleeder holes over night apparently. There was no pretty way to fix this, so sanding back down and staring over was my only option. This sucked! Needless to say I thoroughly blew out the other calipers to ensure no brake fluid was left. This set the tone for the whole project. Perfect paint jobs marred by small oversights. Left rear caliper went off without any issue though, so I guess I can live with 1 of 4. But all in all, when it was done they all look pretty good. The shade of red could be a little brighter, but I can live with that. Much better than the factory color, for my taste. Here are some pics of the journey.
Scientific negotiator
Drives: 2019 Grand Sport Join Date: Mar 2017
DUDE! WOW. Looks fantastic. GREAT WORK!
2019 Grand Sport M7
2018 ZL1 1LE 6MT 2017 SS 1LE 6MT . Matthew 25:40 ΜΟΛΩΝ ΛΑβΕ |
2018 ZL1 1LE
Drives: 2018 ZL1 1LE Join Date: Aug 2017
Well done! Those look great...now how did the brake bleeding go?
#5 | |
That's a whole other story. Started off with one of the vacuum bleeders from Harbor Freight. Good concept but that was an epic fail. Evidently some of the vacuum actually bleeds by the bleeder valve threads or something, judging from other info I found about those types of bleeders. The bleeders in these brakes don't fit nearly as tight as some I've felt before, so I can see that being an issue. Some actually suggest adding teflon tape to the bleeder threads. That's something I'm not willing to take a chance on though. So, today I enlisted the help of my wife to do it the old fashioned way. She worked the brake pedal while I bled each caliper. Progress was definitely made and much quicker, but I still need to go for another round of bleeding. The pedal is still not 100% as firm as it was before. With the vacuum bleeder, I literally had no brakes though. Right now the car could be driven, but I won't until we get another round of bleeding in. In hindsight, I probably should've clamped the brake lines because the calipers were off for a few days. There's probably a ton of air that got in the system. |
#6 | |
2018 ZL1 1LE
I would call them and get the exact kit you need, these are adaptable with other cars too. https://www.summitracing.com/search/...Bleeder%20Kits |
#7 |
902HP 858TQ
Drives: 2018 ZL1 A10 Join Date: May 2018
They look Great! If I had the skill or the patience I would do the same thing... "racing" brake calipers are supposed to be red!
When I would bled brakes I would fill the master cylinder with brake fluid and leave all the bleeders open until they all had a steady stream of fluid coming out... keeping the master cylinder filled during this process of course. If I didn't have a vacuum bleeder than I would do it the old fashion way starting with the caliper farthest from the master cylinder (passenger rear) and work my way around. Hope I was some kind of help... Great job again! |
#8 |
![]() Drives: 2017 Camaro SS Join Date: Nov 2018
That looks great. Nice job!
Kevin
Luceo Non Uro |
#9 |
![]() Drives: 2009 Corvette ZR1 Join Date: Aug 2012
Couple of questions: is the paint rated for brake fluid or for a particular fluid? Where did the decals come from?
TIA, Nick
Here's a link to my 70 Chevelle build thread:
https://www.chevelles.com/forums/12-...aro-donor.html |
#10 |
The paint, primer, and clearcoat are all VHT high temp. The primer is rated to like 2000+ degrees and the paint and clearcoat are VHT's caliper paint line rated to 900 degrees. The decals came from Ebay. I specified what color I wanted for the "ZL1", since I need the 1 to be white now. I also had to request a custom "Brembo" decal because none of the Ebay sellers make them that small normally. It's still actually slightly bigger than the Brembo text on the stock paint job, but I made it work. The decal has to go on precisely and at just the right time while the paint is semi wet but dry enough that it won't pull up when you apply the decal. Then I just sprayed 3 layers of clearcoat over them.
#11 |
Yeah, but is the paint rated for being able to stand up to brake fluid. I once did some testing and very few paints hold up, especially when it's a one part paint in a rattle can.
#12 |
Not exactly sure. But what kind of testing did you do? Prep, application, and final curing are all very crucial to the VHT stuff, as I understand it. So, after painting, and when they are dry enough to handle, the calipers should be baked at 200 degrees for around an hour. This can be accomplished by an oven or on the vehicle itself. But also, outside of an accident while bleeding your calipers, they should not ever naturally encounter brake fluid on the outside finish anyway. Am I missing something here?
#13 |
I missed the bake part - none of the paints I tested required baking. Did you have to remove the pistons and seals - they were probably ok at 200 degrees and I'm guessing that was Fahrenheit.
You must be more meticulous than some of us where it concerns brake fluid. LOL
#14 | |
| Thread Tools | |
