![]() ![]() ![]() ![]() ![]() Drives: 17 SS a8 Join Date: Feb 2010
Effect of rotational weight
I found this website that helps to understand the effects of rotational weight. We have all heard how getting rid of rotational weight is like getting rid of “4” times normal weight. Well it is a little more complicate than that. The calcs at the bottom of the page give a much better idea of rotational weight effects. It gives you mass equivalents.
Here are some of the numbers. Tires = 1.9 Rims = 1.3 - 1.4 Rotor = 1.1 Driveshaft = 1.01 Dropping weight on a tire you get almost double the effect. Dropping weight on the driveshaft give you virtually no additional effect. Nothing on our cars is over 2 equivalent ratio. http://hpwizard.com/rotational-inertia.html#wheelstires
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
![]() ![]() Drives: 2016 Camaro 2SS Join Date: Mar 2016
This makes sense the larger the diameter and the further out the weight sits on that diameter is going to have a larger effect. The closer to the center the less benefit. An axle shaft or driveshaft has no real turning circumference to speak of vs let's say a 30" slick. Cool info in that link
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 SS Join Date: May 2013
Yep my main focus for the past 10yrs thats how I managed a 6.55 @ 104mph in the 1/8 on a heads and cam setup in a 5th gen....
The stock front wheel/tires are 59lbs each. A 17” front skinny with a bias ply tire weighs 27lbs. 64lbs total off the front of the car. Looking at those calcs I am going to average the wheel and the tire ones and call it a 1.65 mass eq ratio.
1.65 x 64 = 106lbs of equivalent loss. Putting that into a hp/et calc shows .11 et reduction in the 1/4 mile on a stock car and .09 for a car more like mine. This does not include loss of rolling resistance or the fact that you will likely hook better getting some weight off the front of the car.
My Rears were 64 lbs, fronts 62 lbs. I saved 100 lbs with my Race Stars and Hoosier slicks and skinnies. Plus my car ran 3 tenths quicker and several mph over the stock wheels and tires. The track temps and air were about the sam so pretty accurate comparison.
![]() ![]() ![]() Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
So switching to non run flat Michelin Pilot sport 4S dropped 5lbs per tire from the stock goodyears. So 5X4=20, 20X1.9=38lbs
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
Wow. Are you comparing worn tires to new tires?
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
#8 |
Cal
Drives: 2017 6th Gen Camaro ZL1 Coupe M6 Join Date: Sep 2013
Great topic! I've read this before in various other literature and online. The information on the linked page is very thorough and I like that it includes calculator tools. You can easily demonstrate the concept with a few bicycles if you turn them over and pedal them by hand. Larger, heavier wheels take a lot more effort (power) to turn. This goes hand-in-hand with gear reduction as the effect is multiplied when you change the wheel height or, more accurately, its circumference.
--Cal |
#9 | |
![]() ![]() Drives: '16 2SS / '05 SRT10 Ram / '65 bu Join Date: Dec 2015
#10 |
