Old 09-14-2017, 10:44 PM   #1
KirkH
DIY-How to install GM splash guards
I just installed the GM splash guards. Very easy install!
Tools:
Trim tool to remove push pin
Phillips screwdriver
Hand riveter
Here's the front:
It is so much easier to remove the wheels to do this install. And you can clean the wheel well carpet with a stiff bristle brush while you are there.
Pop the head of the push pin up and remove. It will not be re-used.
Pull back the liner so you can install the supplied clip nut over the existing hole.
Put liner back in place and screw the supplied mounting bracket in place. Push the bracket up against the body. It has markings or indentations at the point that it rests.
Clean the body where the splash guard will adhere with IPA or a surface stripper like Chemical Guys WipeOut surface cleaner.
Put splash guard in place and line up holes. Use a hand riveter and the supplied rivet to fasten splash guard to bracket. Start with the bottom hole.
Fasten a rivet to the top hole, leaving the middle hole open so you can remove the tape liner. Peel back the tape liner to expose the tape adhesive and press splash guard against the body.
Install rivet in middle hole.
Boom! Splash guard installed!
Old 05-03-2018, 12:40 AM   #2
Soleil
Soleil's Avatar
well done. looks very neat.
Soleil
Old 05-03-2018, 11:21 PM   #3
Marco Falcone
Marco Falcone's Avatar
Drives: 2018 2SS Convertible MBM/Kal
Will the GM react splash guards fit with the GM/OEM Ground Effects package?
Thanks!
2018 2SS Vert. MBM/Kalahari. MRR FS01’s with 285/305 MPS4S. Black Bow ties, A8, MRC, NPP, 6-piston Brembo’s w/ matching rears, OEM Ground Effects/Splash Guards, 8”/Nav. Borla S-type, Pray IM/TB, RotoFab.
Past DD’s of note:
2013 Caprice PPV. (“Company” car.)
1998 Cadillac STS
1996 Impala SS
1969 Cadillac DeVille Convertible
1993 Corvette
1991 Mustang 5.0 LX
1973 Alfa Romeo Spider
1986 Mustang GT T-top
1964 Falcon Sprint Hardtop. (First car, still have the key!)
Marco Falcone is offline   Reply With Quote
