Old 07-08-2019, 01:38 PM   #15
EJR8402
EJR8402's Avatar
Drives: 2019 Red Hot 1SS "Scarlett"
I've had my Porter Cable 7424 for 15 years. No issues, no maintenance.
EJR8402 is offline   Reply With Quote
Old 07-08-2019, 06:27 PM   #16
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles.
Joe M 2012 2SS is offline   Reply With Quote
Old 07-09-2019, 08:50 PM   #17
closs2sx
closs2sx's Avatar
Drives: 1970 chevelle
Originally Posted by Joe M 2012 2SS View Post
Thanks
I have narrowed it down to a flex or Rupes wish I could try both before I purchased and try the Rupes 15 vs the 21
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car
2015 Z06 Z07
Daytona Sunrise Orange Metallic
Dads Car
2013 ZL1 vin 963
Crystal Red Tint Coat/Black Wheels
Exposed Carbon Fiber Insert
6 Spd Manual
closs2sx is offline   Reply With Quote
Old 07-09-2019, 09:49 PM   #18
Joe M 2012 2SS
Drives: 2012 2SS
Originally Posted by closs2sx View Post
Thanks
The Flex is direct drive, and takes a little more work to use. Unless you keep the pad completely flat, the machine will take you where it wants to go, instead of you controlling it. It's takes a few times to get used to this.
The Rupes polishers have literally no vibration at all, which make them very comfortable to use. The 21 will cut a little faster than the 15, and you'll need to buy a separate backing plate for the 21, because it comes with a 6" backing plate, not the 5" you need. Now I have the original Rupes 21, so I'm not 100% sure the newest model can accommodate a 5" backing plate.
Also with only a 5" pad that you can use on the Rupes, getting into some of the smaller areas is impossible.
The Flex can accommodate a backing plate that allows you to use 4" pads.
Also with the Rupes, you need to do the KB washer mod to get the best performance out of it.
If you are only planning on doing your own car, I'd still recommend the GG 6". You can get the same results as the Flex and Rupes can, only it will take longer.
Old 07-10-2019, 10:27 PM   #19
closs2sx
closs2sx's Avatar
Joe thanks for all the info. I think if I go with the flex or the rupes I will get a nano long neck as well. Since you brought up the pad issue and the washer mod I now have to factor those conditions into my choice. I was leaning towards a rupes 15 mark III but now may go with the 21 with the nano as well.
These would be just for my cars (5) and maybe a friend or 2 and my dads as well not mass production but I don't have a ton of extra time so if user friendliness and job quality is not short changed a polisher that works faster is a plus.
MY Car
2015 Z06 Z07
Dads Car
2013 ZL1 vin 963
6 Spd Manual
Old 07-11-2019, 06:19 PM   #20
Joe M 2012 2SS
Drives: 2012 2SS
If you get the Mark III Rupes 21, again, be sure it can accommodate the Rupes 5" backing plate. The 21 does not come with a 5" backing plate, but a 6". Rupes makes 2 different 5"backing plates, the standard and the extra hold.
The extra hold really grips down on the pad, and I'd recommend it over the standard.
The new Mark III 15 is supposed to be much better on modern vehicles with curves, and is able to produce a higher OPM, to equalize the cutting ability of the 21, while having less stall on curves. The 15 also has a 5" backing plate, which is exactly what you want. Of course the KB washer mod is still the best idea to stop machine stalling, and increase cutting ability.
When the Nano mini came out, I considered it to go with my original Rupes 21, and Rupes 3" mini. After speaking with several professional detailers I know who bought it, they said it wasn't worth the cost, unless you are only doing show cars, which are never driven, and looking for 100% complete correction on the car.
There are very few places on most cars my Rupes 3" LHR75E wont get to, and if needed be, I can do those by hand.
I'd recommend that you just get a 3" backing plate for your PC, and use it for the smaller areas.
Old 07-16-2019, 02:14 PM   #21
Haole
2017 SS
Haole's Avatar
Drives: 2017 Summit White 2SS
We I have a question again. I have an opportunity for a few more hours to get the Adam's 15mm long throw swirl killer for about $100 (after and Amazon gift card I just got). Would this be a good investment?
Haole is offline   Reply With Quote
Old 07-16-2019, 03:37 PM   #22
Joe M 2012 2SS
Drives: 2012 2SS
Originally Posted by Haole View Post
We I have a question again. I have an opportunity for a few more hours to get the Adam's 15mm long throw swirl killer for about $100 (after and Amazon gift card I just got). Qoukd this be a good investment?
Yes. Adams has among the best, if not the very best, customer service in the detailing business.
110% satisfaction guarantee.
