Old 11-20-2018, 03:51 PM   #113
Snowblind
Snowblind's Avatar
Originally Posted by Nicul15 View Post
What do think it picked up over your stocker?
When I had the 3.73 gear set the car went into the upper rev range quickly. The ported stock IM was doing okay but my logs were showing a kPa in the 96-97 range on some passes, that's when I knew the MSD was needed. My first logged pass after the switch showed the MAP was restored to 98-100 so the restriction was just about eliminated by swapping intakes. At that time I also swapped to a Circle D and lost 2 mph on the big end, the MSD gave me back the 2mph that was lost in the converter swap. The ported 95mm tb keeps me at almost 100 kPa for the duration of my passes now.
Originally Posted by 18ss376 View Post
Snowblind or Matt what does LTH & WR mean?
Yes, wr is weight reduction and long tubes.
Old 11-20-2018, 04:04 PM   #114
7speed
Drives: 21 SS
Nice, did you switch to ported MSD or non ported MSD?
FBO, E85
11.1@123
7speed is offline   Reply With Quote
Old 11-20-2018, 04:19 PM   #115
Snowblind
Snowblind's Avatar
Thanks. I ported the MSD myself.
Old 11-20-2018, 08:50 PM   #116
biker2k
biker2k's Avatar
Drives: 2018 2ss 1le
hey matt do you have a dyno of after you added the headers to this combo?
biker2k is offline   Reply With Quote
Old 11-21-2018, 10:30 AM   #117
Matt@Tick
Matt@Tick's Avatar
Drives: All GM Performance
I do, but it disagrees with everyone's dyno results of picking up some unreal power. It made about 7 peak hp more, and about 10 more at the top of the pull. Nothing really amazing at all from a header swap. These were with Hooker 1 7/8 headers, full 3" exhaust and no cats. The MSD and tb dyno was done with stock exhaust and a muffler kit.
These same headers are now breathing just over 530 wheel cam and bolt-ons. All corrections are SAE for real world numbers.
Matt@Tick is offline   Reply With Quote
Old 11-24-2018, 09:33 PM   #118
squish72
Drives: 2016 2SS 8AT
Has anyone seen these posts? It's got me gun-shy for the time being of going to the 95 or the 103 anytime soon.
squish72 is offline   Reply With Quote
Old 11-24-2018, 10:09 PM   #119
Puddin
Squish where did EFI post that?
Old 11-24-2018, 10:47 PM   #120
squish72
Hptuners
Old 11-24-2018, 11:43 PM   #121
Puddin
Thanks Squish. Well that sucks guess I'm glad I still got my ported stocker in case I need to switch back for Pray since hes remote tuning mine right now.
Old 11-25-2018, 12:18 AM   #122
Buckscamaro
Buckscamaro's Avatar
Drives: 2016 ss camaro
I helped a buddy swap in his msd yesterday, and I have to say, msd left a lot to clean up on this intake. When I get mine, I'm definitely porting it..
You tube channel:
G's footage
https://youtu.be/VCnanR8qsNg
Instagram: boogieman_racing
Buckscamaro is offline   Reply With Quote
Old 11-26-2018, 08:46 PM   #123
biker2k
biker2k's Avatar
Any one else have thoughts on this
Old 11-27-2018, 03:15 AM   #124
OneSlowV
OneSlowV's Avatar
Drives: 2018 camaro ss
I just bought the lt5 Tb will be here tomorrow I see alont of guys running 10s with it so I call bs lol
2019 charger scatpack FBO 11.16@122
2020 CAMARO LT1 6spd 11.02@ 135 dragy approved
OneSlowV is offline   Reply With Quote
Old 11-27-2018, 05:33 AM   #125
biker2k
biker2k's Avatar
I have mine installed on a stock ported intake, I used weapon x adapter and cleaned out a bunch of material, don't think ive got 95mm all the way through but it is portmatched and definitely wider all the way through, I've only driven it once like that and haven't adjusted tune seemed ok but were talking like 5 minutes of driving, not sure the ecu has adjusted to it... we will see im waiting to do long tubes and re tune before spring..
Old 11-27-2018, 05:56 AM   #126
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
I too just got a 95m tb, and was trying to figure out the intake manifold thing and then I read this, everything come to a screeching halt, that article made me a little nervous. Can we get some tuners or data loggers on here to look into this?
