Old 01-29-2019, 07:06 PM   #183
18ss376
Drives: Camaro
Originally Posted by Matt@Tick View Post
No tune. We messed with it a bit when it was stock to pry some power out of it and it never made more than the baseline. The pull with the manifold and TB were on an untouched tune as well.
Wrong, Because I tried to install your 95mm TB & got 5 CEL's, when I put the stock TB back on & cleared the codes everything was perfect. Also you sent me an email that said the Tick Performance 95mm throttle body will need a tune. So now I can't use it until I get a tune & my Roto-Fab did not give me any CEL's. Also my ported intake for a 95mm TB did not give any CEL's either.
18ss376 is offline   Reply With Quote
Old 01-29-2019, 10:03 PM   #184
cmeJATT
cmeJATT's Avatar
Drives: CAMARO
Do you have a link just for the ported 95mm throttle body?
cmeJATT is offline   Reply With Quote
Old 01-30-2019, 10:08 AM   #185
6spdhyperblue
Drives: 2SS 1LE
The throttle body in the test is the non ported tb. So that is why itworked with no tune
Old 01-30-2019, 10:26 AM   #186
oldman
Drives: SS 6 speed of course
that is my understanding also, unported 95mm. I don't think porting the intake would change the need for a tune. Would get better results tuned.
Old 01-30-2019, 11:32 AM   #187
18ss376
Drives: Camaro
My mistake, thanks for clearing that up. I thought it was his ported 95mm TB.
Now that makes more since when I reinstall it with my tune.
Old 01-30-2019, 11:44 AM   #188
6spdhyperblue
Drives: 2SS 1LE
Yeah it’s confusing because they’re all modified by cnc the bolt holes but you have the option between ported and not
Old 01-30-2019, 12:23 PM   #189
18ss376
Drives: Camaro
Yup, mine is the Tick 95mm ported TB. It will be going on a Pray ported IM & the opening is for a 95mm TB, tuned by Jannetty Racing.
Old 02-17-2019, 09:14 PM   #190
kmccall1978
Drives: 1ss 1le redline
Just installed my MSD and 95mm tb, Drove it around for 10 miles everything was decent, then i drove it later in the day and the rpms at idle are reving to 2k.....also a CEL any ideas?
kmccall1978 is offline   Reply With Quote
Old 02-18-2019, 07:17 AM   #191
6spdhyperblue
Drives: 2SS 1LE
Sounds like a leak. Did you use locktite? Did you give it 24hrs to dry?
How old were your gaskets? What’s the cel?
Also when you guys store these off the car, it doesn’t look like a good idea to leave the parimeter bolts tight. Like most mention, it opens the corners with a gap, giving it a real wavey shape, until you install on the engine. then they close up and it flattens out.
It makes sense to keep the perimeter bolts loose like delivered until you’re about to install. If you leave it in that state for too long, Itll warped.
Crazy they don’t mention that in the instructions
Old 02-18-2019, 07:39 AM   #192
Umbriel
Drives: 2016 Camaro SS
Definitely a leak somewhere, it's sucking in extra air at idle.
Umbriel is offline   Reply With Quote
Old 02-18-2019, 07:44 AM   #193
kmccall1978
I missed the lock tight direction... which bolts? Gaskets were about 2k old. Dont have a reader for the cel yet. And definitely didn’t give this thing 24 hrs ti dry
Old 02-18-2019, 08:11 AM   #194
6spdhyperblue
Drives: 2SS 1LE
Per GM, Blue locktite on the bolts into the heads at minimum. Idk about the others.
I’m pretty sure locktite directions say 24hrs so I’d follow it for these bolts, as they’re known to loosen.
Old 02-18-2019, 08:18 AM   #195
kmccall1978
Ill pick some up, and give it a try, and then report back.
Old 02-18-2019, 08:34 AM   #196
18ss376
Drives: Camaro
This is why I hate the plastic POS on our cars. Why can't someone make an alumium IM? Then you don't need locktite or the wimmpy rubber gaskets.
