04-02-2018, 12:06 PM | #1 |
Drives: 2017 1SS convertible Join Date: Feb 2018
Adding Homelink to a 1SS Convertible
I wanted to add homelink to get rid of my garage door opener sliding around. Here are the part numbers I used to install it in.
Transmitter 23341161 $99.18 Garage Door Opener 22834550 $15.25 plug and play harness from gen5diy http://www.gen5diy.com/Chevrolet/Cam...elink-Harness/ The install and how to get to the upper header portion is simple and plenty of how to videos out there, |
04-08-2018, 01:35 PM | #2 |
Drives: '17 Camaro SS Convertible Join Date: Jan 2017
Hello. Please provide a few links detailing how to access the panel in the convertible. I’m only able to locate details on accessing the panels in a hardtop. Thank you!
04-08-2018, 03:40 PM | #3 |
Drives: Camaro 50th anniversary edition Join Date: May 2017
Thank you for sharing. Meaning if I order the harness and the two others I am able to install the home Link? Is the cut out for the buttons already marked in the panel?
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
04-11-2018, 04:07 PM | #4 | |
http://www.camaro6.com/forums/showth...radar+detector |
04-11-2018, 04:12 PM | #5 | |
04-13-2018, 05:12 AM | #6 |
Now I have another question. do you know on which frequenzy the remote works. We use in Europe. Is it compatible?
Frequenzy (MHz) Modulation 26,975 AM 26,995 AM 27,015 AM 40,685 AM + FM 433,92 AM + FM 434,42 FM 868,30 AM + FM 868,865 FM Is it compatible?
Soleil
04-13-2018, 10:25 AM | #7 | |
Sorry Sir, I do not |
06-04-2019, 05:08 PM | #8 | |
Drives: Camaro SS 2018 Convertible Join Date: Apr 2019
Glad to see you here s well. :-) Did you manage to add the homelink buttons for EU garage openers? Thank you |
09-24-2019, 12:44 PM | #9 |
just installed the Transmitter 23341161
433Mhz -> OK 868Mhz -> Not OK |
