Old 05-01-2017, 10:20 AM   #1
00 Trans Ram
00 Trans Ram's Avatar
Drives: 2017 2SS
Carbon fiber defrost vent cover
So, living in New Orleans, I've been getting a lot of condensation on the windshield lately. As in, every morning. Brought it to the dealership. They said that they've verified that ALL the Camaros do the same thing (customer car in for warranty work, plus 4 new Camaros on the lot). They also checked the voltage going to the damper motor, and it is working properly. Their conclusion was that the damper simply isn't sealing off all the air. Short of completely disassembling the dash, they don't see a way to fix it. So, I've added my name to the list so that hopefully there will be a recall.
But, until then, I decided to do something myself. Got some heavy construction paper and made a template (put it on the vent, pressed down to make dents at the edges, then traced the dents with a pencil). I had to fine-tune the cutout a few times to get it to fit exactly.
When I got it to fit perfectly, I put a 3M Di-Noc carbon fiber sticker/film on top of the paper. Then, I put several spots of double-sided tape on the bottom to hold it in place (the tape strips that come with those wall-mounted hooks works great). The last thing I did was grab some black duck tape and line the underside of the edge nearest the windshield (so that absolutely no air would escape out of the front - only the back that is farthest away from the windshield).
Stuck the whole thing down, and here is the result.
After 3 days of driving, I can report that there is NO condensation on the windshield. It works perfectly.
00 Trans Ram is offline   Reply With Quote
Old 05-01-2017, 03:52 PM   #2
GAHDOOSH
GAHDOOSH
GAHDOOSH's Avatar
Drives: 2017 Camaro 2SS 50th
Can you get a better photo maybe through the windshield?
Would be cool to see how it turned out.
GAHDOOSH
2017 2SS 50th Anniversary Manual, Performance mods: two car seats
GAHDOOSH is offline   Reply With Quote
Old 05-01-2017, 06:02 PM   #3
Dustya
Drives: Overkill Supercharged 2016 CamaroV6
Looks like something bigworm should make available!!
Dustya is offline   Reply With Quote
Old 05-03-2017, 10:20 AM   #4
00 Trans Ram
Drives: 2017 2SS
Will do. Later today.
Old 05-05-2017, 11:03 AM   #5
00 Trans Ram
Drives: 2017 2SS
Sorry - forgot to do this the other day. Here it is, though. Kinda hard to see past the reflection. But, it's always got a reflection when outdoors, and when it's inside, it's dark and hard to see. Essentially, it's always hard to see exactly what it is. I showed a few friends, and 2 of them said, "OK, so where is the part that you made?" (they didn't even notice it) while the other said, "Wow - that looks like it belongs there."
Old 05-05-2017, 02:04 PM   #6
greg72982
greg72982's Avatar
Drives: Black 2017 2SS
Looks great but doesn't this make the defroster inoperable at all times then?
2017 Black 2SS, M6, NPP, MRC, NAV, and black bowties - delivered 6/23/16
greg72982 is offline   Reply With Quote
