![]() Drives: 2017 Camaro 2LT 50th Anniversary Join Date: Sep 2016
Constant 12V Wire
Hey,
Going to hard wire a BlackVue Dash Cam with a Power Magic Pro so I can record while the car is parked. I've been doing a lot of searches, and found numerous threats on switched 12v but limited info on constant 12v. Found one thread where a guy ran a wire from the fuse box under the hood. Is there anywhere closer I can tap into? Preferably somewhere already inside the cabin, or somewhere near the overhead console/mirror/a pillars? Thanks |
#2 | |
![]() Drives: Red Hot SS 1LE Join Date: Dec 2015
Being as how the map lights don't need the car running I would assume there is full time power. Could be wrong though if they cut off after a pretiod of time to save the battery. Not sure is the computer picks up the amp draw. A camera would be minimal I think.
I need Teepee!
Drives: 2019 Camaro SS 1LE Join Date: Oct 2016
Check out the DIY forum, there might be a how-to in there. That's where I found radar detector hard wire instructions (switched power).
#4 | |
My cam should arrive in the mail in about 2 days, so I'll go probing around seeing if I could find anything then, but in the meantime was wondering if someone knows where to look. |
I'm sure those switch off after a while. I have accidentally left mine on, and came back 10 - 15 minutes later to find them off.
If anyone wants to know for future references, I went probing around today looking for a Constant 12V Wire. The Red wire from the 3 homelink buttons is a constant 12v wire. The Yellow wire from the homelink buttons is switched, but it doesn't output at 12v, so best to use anything else than that one.
#7 |
![]() Drives: 2017 Arctic Blue 2SS Join Date: May 2015
I would assume there's still a fuse block in the dash behind the driver's side door like the 5th gen. The seats should be always on 12v. The horn as well.
When I hooked up my power magic pro in my 5th gen I used the seats for my parking mode. The problem I had with the device was it was poorly shielded and caused interference with my key fob, causing it to not work at a distance further than 10 feet. |
#8 |
![]() Drives: 2017 Camaro 1LT HBM Join Date: Sep 2016
#9 |
![]() Drives: 16 Summit white, Ceramic white 2SS Join Date: Jan 2016
Alex I Have both my radar detector and dash cam hard wired to my mirrors power supply. Use a flat head or panel tool to pry down the panel in front of the rear view mirror. (the one with the garage door opener and lights) There are 5 plugs going into the panel that need to be unclipped. The front two grey ones are push in side and pull out, same with the center most black one. The farthest grey plug has a red tab you have to lift then press in first to get out and that is the plug you want to get to. The 5th black plug is a pain in the a$$ and does not need to come off and I just let the panel hang off it while working. With the center grey plug closest to the mirror the black wire on the far passenger side is your ground. The second from driver side purple wire is your 12v switched wire. It should be the inner most purple wire. You can either shove wire down into the connector or strip and piggyback the wire up to you. Then electrical tape it up and plug it all back in and start the car to test.
ez pz
#10 |
Camaro Fan
I just ended up running it to the front fuse block under the hood.
Ordered: Garnet Red Tint coat 2016 Chevrolet Camaro 1SS, Auto, NPP
1100 Status: 8/6/15 3800 Status: 10/13/15 VIN #116519 4200 Status: 12/19/15 Delivered : 12/28/15 |
#11 |
![]() Drives: 2016 Camaro SS Join Date: May 2017
#12 |
Guys use the passenger side A pillar for all your power needs.
#13 | |
Retired fr GM + SP Global
Drives: 2017 Camaro Fifty SS Convertible Join Date: Mar 2017
A8 | MRC | NPP | Nav | HUD | GM Performance CAI | Tony Mamo LT1 V2 Ported TB | Kooks 1-7/8” LT Headers | FlexFuel Tune | Thinkware Q800 Pro front and rear dash cam | Charcoal Tint for Taillights and 3rd Brakelight | Orange and Carbon Fiber Bowties | 1LE Wheels in Gunmetal Gray | Carbon Fiber Interior Overlays | Novistretch bra and mirror covers | Tow hitch for bicycle rack | |
#14 |
Not sure I'm following this. Are you saying route the cable from the underhood fuse box through the A-Pillar trim and up to the dash cam?
