Old 01-28-2017, 04:06 PM   #1
Whitemaro6
Whitemaro6's Avatar
Drives: 16 Summit white, Ceramic white 2SS
HELP! MSD rough idle dying
Hello I just put on the MSD air force intake. I double checked everything, Maf is facing the right way, all the lines where on and good. Started it up and it ran for about 30 seconds fine while it warmed up. Once it was warmed up it just ran rough wouldn't take any gas from the peddle and died. Tried starting it again and got backfire and rough idle again then died. I do not hear any air leaks. Car is stock other that a CAI intake and secondary cat deletes. Car is giving me no lights on the dash just running like its super cammed then dying. Tried starting it twice with same results. PLEASE HELP!!!
Whitemaro6 is offline   Reply With Quote
Old 01-28-2017, 04:13 PM   #2
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
I would keep checking for a air leak, maybe missing bolt, they have been known to ship without enough bolts.
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 01-28-2017, 04:18 PM   #3
Whitemaro6
Whitemaro6's Avatar
I came across that problem actually and replaced the bolt. All the bolts are in it and torqued to spec. Car does not run long enough to get out and check. Really frustrating.
Old 01-28-2017, 04:49 PM   #4
bybcous
bybcous's Avatar
It has to be something simple. Go back through the instructions msd sent and see if you didn't plug something back up, etc. None of the plug wires got pulled out accidentally?
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 01-28-2017, 05:19 PM   #5
Whitemaro6
Whitemaro6's Avatar
I'm going to tripple check everything tomorrow, plugs are a good idea to look at. If I get the same problem then ill take it off and put it on again going slower this time. If that dose not work then Ill just put the stock back on and pray the problem isn't something worse. Fingers crossed. Its acting like its got the worlds biggest air leak but everything is buttoned up :(
Old 01-28-2017, 07:37 PM   #6
2016SS
2016SS's Avatar
Drives: 2016 Summit White 2SS
If this only happened once the new intake was installed! Then install the OEM back on headache I know but it ran then didn't it? And see if it starts that would weed out the problem being the aftermarket intake!
2003 Cadillac CTS Sold
2006 Nissan 350Z Sold
2008 Cobalt SS/TC Sold
2016 Camaro 2SS Summit built 3/28/16 delivered
2018 Camaro ZL1 cancelled by GM 😡
2019 Corvette 2lt Z51
2016SS is offline   Reply With Quote
Old 01-28-2017, 08:53 PM   #7
LibertyHill
LibertyHill's Avatar
Drives: 16 2SS 6MT NPP MRC / 15 K1300S
Seems like a MAF problem???
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC
LibertyHill is offline   Reply With Quote
Old 01-28-2017, 09:10 PM   #8
oldman
Drives: SS 6 speed of course
sumpting, my MSD idles like stock.
Old 01-28-2017, 11:04 PM   #9
Whitemaro6
Whitemaro6's Avatar
God I really hope not. I did disconnect it but it went back on fine. It's something. I hope nothing to hard to fix.
Old 01-29-2017, 12:31 PM   #10
Whitemaro6
Whitemaro6's Avatar
Thumbs down
Whelp found my air leak. Put the stock im back on and she purred like a kitten. Taped off the runners on the msd and poured water in it. Lo and behold the back right corner has a massive leak. I took the MSD apart and resealed it three times with the same result back right corner leaking. (See video of last try). Extremely disappointed especially for the price of this unit I was unimpressed before but now i'm really bummed.
https://youtu.be/ise8KGEL3DY
Old 01-29-2017, 12:34 PM   #11
Whitemaro6
Whitemaro6's Avatar
sigh......
Old 01-29-2017, 12:49 PM   #12
bybcous
bybcous's Avatar
Exchange it, it gives good gains.
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 01-29-2017, 02:22 PM   #13
jdasnt3
jdasnt3's Avatar
Drives: 18 Silverado 1500
Sorry to hear about the problem with the intake.
Old 01-29-2017, 08:21 PM   #14
AdmAnt13
AdmAnt13's Avatar
Drives: '16 Red Hot 2SS M6 NPP
"Dear MSD.. WTF"
'16 2SS, M6, Borla Atak
AdmAnt13 is offline   Reply With Quote
