Old 01-27-2016, 03:21 PM   #15
Sales @ CAI Inc
Sales @ CAI Inc's Avatar
Drives: 2010 SS/RS Supercharged 427 Build
Great write up!
Sales @ CAI Inc is offline   Reply With Quote
Old 02-02-2016, 07:59 PM   #16
camarorick
camarorick's Avatar
Drives: .
Cool mod !!!
Thanks for posting this
I just finished installing this mod, and have one thing to add... To avoid grinding a notch in your fuse box to hook up to negative, there is a negative connection inside
camarorick is offline   Reply With Quote
Old 02-02-2016, 10:01 PM   #17
jimmypop13
Drives: 2016 camaro ss
Thanks for the tip! This is what I wanted to do but I had no clue how to search for a ground. I'll do this this weekend as I'd much prefer to have it all tucked away.
EDIT: I switched my ground to the same as yours a few weeks ago. Works great and competely hidden. Very cool. Thanks
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS
RIP : 2002 WS6 Black, A4, 355rwhp
jimmypop13 is offline   Reply With Quote
Old 05-13-2016, 01:46 PM   #18
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
Anyone remember the name of the mod that's out there that has this connected to a key fob so you can switch the NPP from stealth to track while you're driving? I should clarify that what I'm referring to was something packaged and being sold by a forum supplier.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge
93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno)
LesBaer is offline   Reply With Quote
Old 05-17-2016, 05:39 PM   #19
SimMan
SimMan's Avatar
Drives: 2011 SIM Convertible
Send a message via Skype™ to SimMan
Look at Forza. Is this what you are referring to?
SimMan is offline   Reply With Quote
Old 05-17-2016, 07:04 PM   #20
jimmypop13
This mod actually comes with two keyfobs or you can use the homelink buttons. iMBAPrice® 12V, 15 Amps, Heavy Duty Boat and Car Universal Remote Control Kit https://www.amazon.com/dp/B00LMICSIQ..._hl7oxb858T1B5
Old 05-17-2016, 07:31 PM   #21
1hevy_chevy
1hevy_chevy's Avatar
Drives: Nightfall Gray 2016 6M 2SS
+1
http://www.forzacomponenti.com/exhau...ller_main.html
1hevy_chevy is offline   Reply With Quote
Old 05-17-2016, 08:32 PM   #22
JFM-jr
JFM-jr's Avatar
I just installed the Forza unit and it works great. I will be doing a review shortly just waiting for the owner on Forza to get back to me.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 05-17-2016, 09:04 PM   #23
LTWon
Drives: 2016 2ss
Originally Posted by jimmypop13 View Post
No this will only keep the rear valves open at all times as it controls whether fuse 51 is in or not. There is another fuse for the afm valves but it will throw a code if pulled. You would need to buy the Range device to keep afm off or tune it out
Where do you get this range device from?
LTWon is offline   Reply With Quote
Old 05-18-2016, 07:53 AM   #24
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
This looks great!
So if I'm understanding this correctly this modification is totally reversible if you decide to return back to stock at some point? No damage to any stock components if the ground in the fuse box is utilized?
I also wonder if a phone app controlled switch module could be found with a little more research. May have just found my first side project for when I get the car.
Maybe this My N3RD would work
http://www.gizmag.com/myn3rd-switch/30554/
Old 02-22-2018, 11:24 AM   #25
srcstc
I've been putting off buying a mild to wild cause I didn't want to cut a notch so this is great.
srcstc is offline   Reply With Quote
Old 02-22-2018, 02:35 PM   #26
jimmypop13
Yeah if you follow post #16 for the ground, everything is contained under the fuse box lid. I'm so glad he found a ground for us. It's Soo much cleaner this way
Old 02-22-2018, 07:15 PM   #27
ssmike
BL1ZZRD
ssmike's Avatar
Drives: '16 Camaro 2SS, '20 Equinox Redline
Here’s how I did it. No notch needed!
ssmike is offline   Reply With Quote
Old 02-22-2018, 10:55 PM   #28
jimmypop13
Looks great!
