Go Back   CAMARO6 > Members Area > Ask the Camaro Team
Old 02-02-2018, 05:21 AM   #15
BurningMan
BurningMan's Avatar
Drives: 2017 Camaro 2SS / 2012 CBR1000RR
My understanding is the crimps are there as a deformable structure to protect upstream exhaust and engine in the case of a rear end collision. Power losses? I have no idea and not worried about it.
BurningMan is offline   Reply With Quote
Old 02-02-2018, 07:25 AM   #16
travislambert
Drives: '17 ZL1
I've seen that theory posted several times, but I'm very skeptical of that one. If that were true I think we'd see similar crimps on all production exhaust systems.
Also, it does look like the exhaust may need to route around some bracing on the convertible models. I suppose the exhaust could have been designed first and the bracing just took advantage of the space, but that seems unlikely. GM simply using a single part that would work for both the coupe and convertible models seems very reasonable.
Maybe after some of the other burning questions get answered, we can get an official answer from Al.
travislambert is offline   Reply With Quote
Old 02-02-2018, 11:45 AM   #17
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
Originally Posted by parish8 View Post
here is what holly is claiming with their crush pipe delete kit.
I would expect the crimped section to have a significantly higher impact on performance at high flow conditions compared to low flow conditions. The dyno chart shows a similar delta at low speeds (lower flow) and high speeds (higher flow). Whatever caused that delta was likely not the crimped sections.
Mishimoto already ran a back to back test showing transparency between the crimp and full tube in that section of the exhaust:
https://www.mishimoto.com/engineerin...he-crimp-myth/
The crimp definitely reduces cross sectional area (significantly), but is so far downstream from the combustion chamber that the exhaust gas has cooled substantially and does not cause much impact on the torque curve of an otherwise stock car. As HP levels (and exhaust flow) increase, I'd expect that could be a bigger factor. For similar reasons, the stock SS exhaust produces about the same torque/power curve as the optional NPP exhaust.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 02-02-2018, 12:00 PM   #18
HDRDTD
It'd be great if we could simply find someone with a ZL1 convertible that'd be willing to take a few photo's of their chassis where the exhaust crimps are to confirm positively that the crimped portion does indeed coincide with the vert chassis bracing.
Old 02-02-2018, 03:43 PM   #19
Wierd Harold
Drives: 2017 2lt rs
2lt has same crimps,I think it's a ground clearance issue as well as suspension clearances
Wierd Harold is offline   Reply With Quote
Old 02-02-2018, 06:47 PM   #20
GA Camaro 2SS
GA Camaro 2SS's Avatar
Drives: 2017 Camaro 2SS Convertible
I have a 2ss vert and have seen these crimps. Didn’t pay to much attention. I’ll crawl under ther in the morning and get some pics. I have the braces unber there also but can’t remember exactly how it all lines up. Will update in the am.
GA Camaro 2SS is offline   Reply With Quote
Old 02-02-2018, 07:14 PM   #21
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
The company selling the delete kit....
...ya. I can see how their test is objective and not bias.
Old 02-02-2018, 08:48 PM   #22
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
So is the 3% change in CF the reason the blue line is 3% higher?
Old 02-02-2018, 08:58 PM   #23
travislambert
Drives: '17 ZL1
That's not really how it's supposed to work, but I had a similar thought when I first saw the chart.
Old 02-02-2018, 09:28 PM   #24
Gunkk
Gunkk's Avatar
Yeh I know it’s to compensate back to “STP”... it just looks bad. 6 months between runs is a while. I’d rather see a same day test.
Then I’d ask why there was low end torque improvement when a flow restriction should really only benefit the top end when the engine is at max gas output. The whole thing smells a bit off to me.
Old 02-02-2018, 09:44 PM   #25
vtirocz
vtirocz's Avatar
The same day test is here: https://www.mishimoto.com/engineerin...he-crimp-myth/
That data makes more sense to me.
Old 02-02-2018, 09:47 PM   #26
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
At one time there was an issue with some aftermarket exhaust systems that touched the cross member and slight rattle caused the appearance of knock which would retard timing and pull power.
Not something you want to deal with.
Crimps have definitely been shown as a non-issue as far as power is concerned.
The cross-sectional area of the pipe is virtually unaffected. This was a clever, albeit unconventional solution to an annoying problem. Don't let the look of it get under your skin and waste money that could be spent on a more effective mod. Mishimoto's test is good...this video helps shed some light, too...
Old 02-02-2018, 09:49 PM   #27
waterman
waterman's Avatar
Drives: Grandad's C2 L89
Nice find. Thanks for posting.
2018 ZL1 1LE sw/PDR
Old 02-03-2018, 11:31 AM   #28
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
With this dead horse, hopefully this will put this to bed.
We (the company I work for) build the exhaust for our cars, we (along with GM) develop this exhaust to perform a specific way. With out revealing details, I can assure you the crimped section DOES NOT lose or gain HP in any way shape or form. Doe it have a hindrance on sound? maybe to a slight degree that you would have to have the best ears possible to even identify it. Prior to the release of our cars, it has been tested for probably 18 months before its reveal. I hope this clears it up.
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
