Old 03-19-2017, 08:54 AM   #15
laynlo15
Drives: 2022 Lt1 A10
Just 7 lbs, I data logged one time and it pulled a degree down track just before the traps, but it pulled hard all the way down track. I think the slicks might be hurting my 60' times but I won't change as they are easier on the drive train on the launch then drag radials are. I'll give up a few hundreds to save axles and drive shaft failure. DA was negative 300+
Old 03-19-2017, 09:00 AM   #16
HVR
HVR's Avatar
Drives: 16SS-A8-Magnuson-SW-Gforce
When it pulled timing was it hitting a knock sensor? Still great times for 7psi. you have a bunch left in there
HVR is offline   Reply With Quote
Old 03-19-2017, 09:40 AM   #17
laynlo15
No it didn't, pulled 1 degree at 5200 rpm
Old 03-19-2017, 09:53 AM   #18
Running good...
Old 03-19-2017, 10:10 AM   #19
laynlo15
Should be good competition for an A10 with drag slicks or DR's
Old 03-19-2017, 10:15 AM   #20
I hope you're right... Will be finding out soon.
Old 03-19-2017, 11:22 AM   #21
DFW1LE
DFW1LE's Avatar
After that great performance, what are you planning for an encore?
Old 03-19-2017, 11:40 AM   #22
cleoent
cleoent's Avatar
Drives: 16' Camaro E-Force SS
Does the canned Maggie tune have any knock at all?
Great times!
Leo
2016 e-Force 2SS
Instagram @cleoent
cleoent is offline   Reply With Quote
Old 03-19-2017, 11:47 AM   #23
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
Congrats man..
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 03-19-2017, 11:57 AM   #24
laynlo15
I'm not using the canned Maggie, I am using Mikes tune from Magnacharger but its the one he ran in his car with the same setup. I haven't run the canned tune since we added the intercooler. Glad I made that change, however I do think without the intercooler and the canned tune it still would have run very low 11's. I can't believe how hard this car pulls all the way down track.
Old 03-19-2017, 12:27 PM   #25
Brianw36
SNSTRSS
Brianw36's Avatar
Drives: 2016 Camaro 2SS A8
Congrats. Great times. Love these cars!
2016 Black Camaro 2SS A8 NP
Brianw36 is offline   Reply With Quote
Old 03-19-2017, 12:35 PM   #26
laynlo15
Retune this week and 5 gallons of VP MS109. If no wind or tail wind I should be solidly in the 10.60's at over 130. I was right about the 10.80's and hope I'm right about the 10.60's. I'll eat some crow if I'm not. Ha, hate birds.
Old 03-19-2017, 01:34 PM   #27
DapperDan
DapperDan's Avatar
Drives: 2017 1SS A8 Nightfall Gray
Congrats on the times you are on it!! Why do you think the slicks are hurting your 60',and why would a DR be harder on the drive train only thing I can think of is a little stiffer side wall but wouldn't the DR little bit of slippage make up for the shock on the hit. Educate me I haven't been down the strip is 15yrs getting ready to go back with this new camaro so I'm trying to absorb everything I can from you guys
DapperDan is offline   Reply With Quote
Old 03-19-2017, 02:02 PM   #28
laynlo15
Yes your right, the side wall absorbs a lot of shock and could cause a little lag in the launch. This is a good bracket car also, 5 passes within 3 hundredths of a second even if the slicks might cost a couple hundredths it is very consistent, I've run drag radials lots of times and don't remember them having the consistency of the slicks.
