Which alignment for a ZL1 on 1LE spec wheels/tires?
Im noticing a lot more wear on one rear tire than the other. Im thinking this is an alignment issue.
I have a ZL1 on ZL1 1LE wheels and tires. I have the street alignment for a stock ZL1, but I'm wondering if I should get the ZL1 1LE alignment since I have the same tire and wheel setup. Any thoughts on this for fixing the uneven wear? |
Street or track days?
Where is the wear at? Across the entire tread or on the inner shoulder? |
Toe kills tires. Set your Toe at 0 Front and Rear.
