Dead Pedal Removal
Does anyone know how to remove the "dead pedal" from the car? I bought the ATS brushed pedal kit and it comes with the dead pedal and I read in a few places that dead pedal will fit our cars.
1 Attachment(s)
Take the side kick panels off ..lift up on the carpet .the dead pedal and foam will come up with it. then you're going to have to remove the press on fasteners.. you will then have the dead pedal completely removed.
Thanks all
I'm trying to figure out how to put probably a Cadillac version of the pedal with the brush metal in
2 Attachment(s)
Thes are the ones I ended up using
https://www.camaro6.com/forums/showthread.php?t=525129 (auto) https://www.camaro6.com/forums/showthread.php?t=530166 (manual) instead? They are very high quality and easy to apply, and if you have the GM performance pedal cover kit, you just need the dead pedal cover. I have the auto version and am fully satisfied. |
1 Attachment(s)
I agree I had a set before the ones in using now . his pedal covers are as good as OEM and his customer service is fantastic.. highly recommended
Excellent Product & Customer Service!!! |
+2 have had my dead pedal for a while now. Excellent customer service.
What glue did you folks use on Hartford's dead pedal for the M6 version?
Turned out to be a very bad idea, I cleaned up the small pieces of goo that squeezed through for days. Next time, if ever, I'll just use super glue. |
