Heads Up-2018 SS Brake Pad Change
I hate brake dust, so I decided to change the brake pads on my 2018 convertible with heavy duty brakes. I chose Power Stop ceramics for all four wheels. Installing the fronts went fine but the REARS DID NOT FIT because the parking brake "shoe" is in the way on the inboard side. I bought the Power Stops from Carid and they are exchanging them for EBC Red brake pads that are supposed to fit. Carid is eating the shipping so I have been treated fairly but I thought a heads up to 2018 owners might be helpful. :sad0147:
Thanks for part numbers and everything.
Yep, part number would be good. And what about the brake dust?
Like others have said... part number needed. I can't imagine that 2018 brake is much different than 2016 and 2017... But I could be wrong. Like most peeps, I used these without issues: Power Stop Z26-1474A Z26 Power Stop Z26-1718 Z26 |
I had no problem with the powerstops
Put them on my 18 and they slid right in. Mine is a coupe A8 so I wonder if your convertible is different?
Going by memory here which isn't so good these days but when I installed my PowerStops I believe I had the same issue. I think the back pads are different i.e. there are inside and outside pads.
Yes with the rears the pads matter. The one with the pad depth indicator has to be on the outside pad
The fronts fit. Part#Z26-1835 (Carid). The rears don’t. Part#Z26-1053 (Carid) The tech at Carid stated the the rears don’t fit a 2018 even though the website says they do. They are exchanging them for EBC Red Stuff rears that are supposed to fit. |
I had the z26- 1718 for the rear of my car. I got a 2016 SS but I don't know why if would be different
https://www.powerstop.com/?s=Z26-1835 https://www.powerstop.com/?s=Z26-1053 |
Yea they gave you the wrong pads!
Same here. Thru Amazon. These fit and no dust. I've had them on for 7 months. No issues. Power Stop Z26-1474A Z26 Extreme Performance Carbon-Ceramic Front Brake Pad Set and Power Stop Z26-1718 Z26 Extreme Performance Carbon-Ceramic Rear Brake Pad Set
Front:https://smile.amazon.com/Power-Stop-...70_&dpSrc=srch Rear: https://smile.amazon.com/Power-Stop-...70_&dpSrc=srch |
