hud) head up display install help
does any 1ss guy already installed a (HUD) on their car?? i want to buy one but i cant find instructions on how to install.. please help
It would probably be easier to sell your car and buy a car that already has one. My guess is you would have to swap out the entire dash, all the wiring, and the windshield.
-Geoff |
Yea, you will get a double image if you try to put a HUD on a regular windshield. There is some special treatment to block the back reflection (or is it the front, I can't remember).
-Geoff |
2 Attachment(s)
Theres this option plugs into your obd2 port but dont know how itll work with the humps in the dash above the cluster
1 Attachment(s)
Another alternative is from the Sharper Image... $100
https://www.sharperimage.com/si/view...H9dRoCdE_w_wcB |
As I recall there were a few Camaro5 forum members that said the HUD windshields were $800 for the 5th Gen. You could always call a glass shop to see how expensive they are for 6th Gen.
Installing the HUD in a 5th Gen Camaro was possible. I don't know how many people also replaced the windshield when adding a HUD. Here is one of many threads: http://www.camaro5.com/forums/showthread.php?t=146851 |
Wouldn't a windshield replacement be covered under the "Comprehensive" section of you insurance policy? I would think it would be the normal $50 - $200 deductible. Since it is under the comprehensive section, it should not affect your rates, unless you have to have several replaced. Just my 2 cents, only worth a single penny in today's economy. |
Unless the HUD/Windshield configuration has changed considerably, with the HUD windshield having a reflective film added to the area of the HUD display area. I would not say that the windshield has a huge role in it. I added the HUD in a 2008 C6 after the fact without any issues vis a vis the windshield.
Just looking at the windshield in my 2SS I can't see anything different or special about it. Is there some way to tell if it has a special coating?
Safelite windshield quotes:
$608 (HUD) $430 (Non HUD) |
