Best intake ?
Hey guys , I would ask you a about the best performance intake ?
I am buying one of these 3 CAI please help. 1-Roto fab 2- Airaid 3 afe Thanks. |
Why not Cold Air Inductions? That should be one of the choices as well, in my opinion.
CAI or Roto-Fab.
Michael |
ROTOFAAAAAAAAAAAAAAAAAAAAAAB, it looks the best.
1 Attachment(s)
RotoFab, independently tested by several shops across the nation to be the #1 intake available.
Rotofab is the only aftermarket I would go with, or just keep it stock with a K&N filter
Best intake for the money is the stock one that came on the car. I haven't seen anything results that make me want to rush out and buy any of the aftermarket options, unless you are adding others things and changing the tune. If I did something, based on the current available options I would go with the rotofab.
The stock intake is a restriction once you start deviating from a bone stock setup. We've done back to back testing and RF clearly showed significant gains (10+ RW) with a ported IM/TB. FI shows gains of 30+ RW.
Tim |
I must have missed the thread that showed a 30hp gain on a FI application. Can you point me to it? The thread I read on a maggie, showed 11hp gain at the top of the RPM range with little or negative gains through most of the band.
http://www.camaro6.com/forums/showthread.php?t=467569 - 40 hp gain over stock w/ Heartbeat supercharger
http://www.camaro6.com/forums/showthread.php?t=473257 - 39 hp gain with LT4 supercharger. I hope these help! Michael |
