1-2 synchro going out
When accelerating hard, gears grind when I try to shift from 1-2. Or if I try to do a steep downshift to 2, same thing. Dealer service manager took it for a drive, said it's the synchro- he's talking to GM as to whether to open it up or just replace the tranny.
Question is: will they try to blame my skip shift eliminator? should I pull it before I take it in? |
It's always a good idea to have a stock car when you're having warranty work done.
Sorry to hear, first syncro issue I've heard of on these...
Depending on the dealer they may use any reason to scrap warranty. I wouldn't chance it. I'd take it off.
If you pull it out you increase your chances to 100% that it won't be an issue. If you leave it in there - you are rolling the dice. I personally don't ever count on luck when I have an option I can control. Good luck with the warranty repair!
Let us know what the dealer says... |
It should be a complete swap with a new unit. If they approve it.
Take the skip shift off immediately and deny ever using it. In the companies defence you have synchro problems and you were using an after market transmission product. They do have a leg to stand on and deny you warranty. Most likely your dealer won't nark you out, and they'll make money off the labour and keep a happy customer(you). |
So they're "replacing 2nd gear". I'm kind of surprised, when I asked why, the service advisor said that "GM makes the call".
