Passenger Rear Spring Problem
1 Attachment(s)
Installed by yours truly...
Why does this happen? I can install it in the right spot, but it comes out when I go over a bump at highway speeds. It is only this spring out of the 4....Did I tighten it too tight? The image is upside down....The top comes out of it's place. |
That's weird the bottom is seated ok and up against is' t stop but the ? ,you sure it's tight enough instead of to much for it to pop like that.
