Vitesse won't turn off
Is it normal for the VTC display to stay on even when the car is off and has been sitting for a while.
Might seem like a dumb and obvious response....but can you (and shouldn't you) just unplug it when its sitting a while?
Yes it's normal. It goes off after about a minute after you exit the car.
OP. Mine turns off once the dome lights go off (when I exit the car and close the door). If it stays on much past that then something isn't right. |
Mine does. Sometimes it'll cut off after a minute, sometimes it seems to stay on for awhile.
Bear in mind, I have removed my cabin wiring harness in the past and taken it to the auto parts store to make sure I'm getting the right switch. "Easy" doesn't necessarily matter to me. :lol:
Mine just stays on, i left the car for an hour and came back and it was on
Edit: nevermind, it turns off after a minute but when you open the door to come back in the car, it turns on again. |
I had the same question so I emailed Ahmed at Vitesse about it and he said it was normal and will shut off after a few minutes after exiting the car.
Even if it didn't shut off, the draw would be so low it would take weeks to drain your battery down. I think. Ha!
Once you open the door it boots up...same thing with my Aeroforce Guage hooked up to the OBD2.
mine shuts off in a minute or so after I shut my door
I installed the controller on Sunday and tried to start my SS today and the battery was to low to turn the engine over. It has a new battery so the drain is coming from somewhere and the only thing different is the controller. Once I get the battery charged up I will keep my eye on the controller to make sure it turns off.
