5th to 6th gen fitment
Anyone know if the 18" 5th gen wheels will fit the 6th gen SS with the standard Brembos? I believe it's a 4 piston setup on the standard 6th gen SS? I'm curious if they will fit without a spacer, or if a spacer is needed what is the minimum size, and will there still be enough threads on the studs. Thanks
Did you ever get any answers to your question? I am looking for the same info, I am wanting a full size spare.
Never got an answer, but based on some recent events I'm thinking they won't fit.
I had the squared setup with 1LE wheels on my '14. I had 20x10 +35 on all 4's.
The wheels wouldnt work on the fronts as it hit the suspension. Hope this helps. |
1st thing I tried was my 18" Weld setup on the rear where the tire circumference was the same as stock 5th Gen and it wasn't even close. (too big) |
2 Attachment(s)
The Wheels will work but the tires will not. I put shorter tires on my Welds and I did run them on a ZL1. Here they are on with no spacers. Attachment 1050067 Attachment 1050068 |
