Smoke blowing into cabin
So I’ve had an eventful morning with my Camaro today... got home from work to move it... dead battery, so took me a while to work out how to access the battery in the trunk with no power to open the trunk from the outside... got that done, and took it for a drive... 5 minutes in, white smoke starts filling my cabin. Doesn’t smell like burning plastic or rubber or anything else I’ve smelled from a car before, so quickly pulled over fearing an electrical fire given the recent battery problems but nothing... started driving home and smoke came back. Any ideas? Don’t really feel like blowing my car up this close to Christmas 😅
If it's coming from the vents, I would suspect a broken heater core.
You would know if it was electrical. -S |
No sweet coolant smell?
Well I’ve never smelled burning coolant so can’t say for sure that was it. It was kinda a sweet smell, rather than the bitterness of most other smokes. Heater core sounds likely, going to get a quote on it on Monday
Yep sweet is antifreeze.
So I went out today to retest it... heater cranked, fan on full, drove for 30 minutes and no smoke, no smell... any way it could’ve just been a false alarm? Like an overflow from the cold or something? I haven’t been able to replicate it and really am hoping I don’t have to spend the money on that... waaaaay more fun things to spend on lol
Check the floor under the glovebox and see if it wet anywhere. Maybe stick your hand under the carpet and feel around. Heater core leaks usually wind up there.
Or it could of been a plastic bag stuck and melting on your exhaust. That’s a common problem in New York and used to grind them off peoples exhaust all the time. |
Another heater core symptom is fog on the inside of the passenger side windshield that won’t go away even with the defrost on.
No permanent fogging, and no wetness under the glovebox or signs of any moisture under there
And coolant loss of course..
Were you parked in the median while this was happening, just asking...
Your white "smoke" sounds like water vapor or coolant. The smell of coolant is strong and unmistakable, so maybe water? Was your car sitting outside during a severe rain storm?
Car was sitting outside and had a nice coating of ice on it. Hadn’t been driven in a few days. Just drove another 80 miles with heat on and nothing so think I dodged a bullet here. Thanks for all the input
