Oh, it's just a battery change....
I am inclined to believe that there is a front row parking spot in the garage of Hell for whomever engineered the battery system in the Cadillac SRX. It required 4 different socket sizes, pliers, a screwdriver, a rubber mallet, hands smaller than mine, and at least 5% of my engineering degree to change the damn battery. :mad: :mad:
The fact that it was under 20 degrees was just bonus. |
GM general mistake as my Ford friend would say
Dammit Barra. Did I do it right?
gotta try to keep the masses coming back to the Stealerships somehow!
Challenger has the perfect location the trunk LOL
Try changing a battery in a CLS550.
I figure its done because pretty much nobody buys a new car with 'ease of maintenance' as a priority. When buying used? Sure, sometimes. But not new. And most of those pain-in-the-ass things only come up after the warranty expires and likely with a 2nd or maybe 3rd owner. So its not going to cost GM (or any other automaker) extra to pay for the work to be done nor a new sale from an annoyed owner. Meanwhile, all they get in return for doing a little more design for maintenance is a bit less less griping from mechanics (of both the professional & shade-tree varieties). Thats not worth much. |
Read somewhere that on the 2019 Ranger you have to put the truck on jacks and remove a wheel to swap the battery. No battery replacement procedure, unless its' an EV, should say "Step 1: Lift the vehicle".
One of my old bosses had a car that the battery was under the back seat. In order to change it you had to tear apart the whole back half of the car. First you had to remove the trim along the doors and the back window to access the bolts holding the back part of the seat, then you had to remove the back to gain access to the bolts holding the bottom part of the seat so you can remove it to reach the reach the battery. |
Now, new reports are saying you don't *really* have to remove the wheel, but you do have to turn the wheel all the way one direction to access a panel to get to the oil filter. Doesn't seem much better. |
Nothing surprises me anymore. BMW is worse. Not easy to get to, but the car has to be programmed to the exact size battery installed in the car, and even if you put an identical battery back in, the battery has to be "registered" to the car to tell the charging system there's a new battery in the car. If a new battery isn't registered, it won't last even a year at best, because the car charges a new battery differently than it charges an old battery.
