Two weeks ago i flew up to SC and drove a 2ss 1le home 9hrs no issues. The car has 5100mi and was previously owned by GM themselves, and its a GM certified pre owned.
I did all the track prep and went to a track day Sunday, in the first session going around a 40mph left hander, the TC turned back on, service rear axle, loss of hp, sounded like it was down a few cylinders, CEL flashing, car shaking so i pulled in. Dreaded(from what I’ve read) P0300 code. Disconnected the battery for a minute, reconnected and all good, no more codes no more shaking, went for a test drive and everything was fine so i went out for the next session. Next session at the end of a 120mph straight when i lifted off the gas on a left kink it happened again, i noticed both laps i ran over the turn 1 curb. First session it happened 2 corners after the turn1 curb, second session it happened the second the left front hit the turn 1 curb. The track is homestead Miami and its part of the line to run over the curb w the left sides. I can verify exactly when the issue occurs because the PDR shows “PTM race” turn off.
Pulled back in the pits disconnected the battery and drove all the way home 2hrs 80-85mph no issues. Did 5 hard pulls with the car hot and no issues. Reinstalled the stock intake (car has a corsa axle back and cold air inductions intake) and took it to the dealer this morning. They called me and told me they couldn’t replicate any issue and “did a software update.” How would you guys feel about that? I get not much they can do with out a CEL present, but I’m just really concerned about this issue w my new to me 1le.
Some factors to note is the car did sit for 5 months between me buying it and Gm offering it for auction to their dealers. The car came from Michigan and i live in FL, any factor there? It happened both times on left turns, both times after hitting the curb on the track.
Also, there is a big fire next to the track
http://https://www.local10.com/news/local/2021/04/30/large-brush-fire-uncontained-in-miami-dade-county/ a 2019 ss 1le and a C8 we were running with also had same on track issues as me within 10minutes of each other. all of us had very different codes tho. We all got gas 40+ miles away from each other on different days so we dont think it was bad gas. There was tons of ash in the air from that fire, could that be a factor?
PDR of incidents -
Session 1, hit curb turn 1, turn 3 PCM race turns off (issues start)
http://https://drive.google.com/file/d/1cu3WyJ8oTkGs3s5YGNaeQf-qlZszRIjO/view?usp=drivesdk
Session 2, notice PTM race shuts off as soon as the car hits the turn 1 curb
http://https://drive.google.com/file/d/190N8RukwZU_t-1hDchu-WPyIl9_nEMZy/view?usp=drivesdk
I would think if it was valve springs or a loose plug wire or something the battery reset wouldn’t have fixed it, but the curbs have me suspect now of something loose?
Any insight is very appreciated
