VR blower package vs local shop
Am I retarded to even consider Vengeance Racing PD stage II package + meth...
Magnuson TVS2650R – includes Vengeance Racing valve covers and coil relocation kit Cold Air Intake System GM 3 Bar MAP Sensor Mighty Mouse Solutions Catch Can System 2” Stainless Longtube Headers 3” Stainless Connection Pipes with Green Cats GM Exhaust Gaskets 180* Thermostat High Performance Spark Plug Set Vengeance Racing LT Plug Wires Vengeance Racing High-Temp Spark Plug Wire Insulators Tuned If I can get the following for literally like ~$2K more out the door from a local shop (very reputable)? PC D1X: Stage II I/C, helical, race bypass valve, black finish PP ported heads/TB/IM PP Cam kit with upgraded parts (johnson lifters, cometic gaskets, ARP bolts) 2” TSP LT with offroad pipes GPI Forged drop-in piston/rods LT4 Fuel (HPFP, injectors, in-tank) AUX lowside kit Meth kit FF sensor Monster triple disc clutch Tuned Granted VR is based on a PD blower which is little more expensive plus valve cover and coil relocation kit, but good lord they’re expensive :confused0068:(going off of their web posted price). I’ve no doubt they are top notch (techs, facility), meticulous when it comes to their work, and provide fantastic customer service (e-mail exchange and good reviews), but does it warrant the extra extra extra cost? Their stage V pro charger setup is somewhat comparable (still lacking in terms of parts) but after taxes and vehicle shipping, that's well over $30K. What do you guys think? |
I'm in luv with the racing valve coves and coil relocation kit.
I'd go with the cam, heads, forged pistons, there is something to be said about an M6 with cam, heads and headers. You can look at my sound files and the LT is gonna be HECK of loud. LT no cats: https://www.youtube.com/watch?v=FYFU...ature=youtu.be stock exhaust:https://youtu.be/AfoP1LPXdUo I skip the meth kit and go with Lingenfelter HPFP and minimal LT4 injectors (or bigger) you are octane limited to 10 PSI or so 3.85 to 4.0 pulley. I think I'd save money on the ported tb and manifold and spend on bigger injectors. |
It sounds similar at idle, but at 45 mph the stock exhaust is stock or near stock. The LT with no cats really is terrible on a M6, better with cats, even livable but I'm looking at being done and going to a C8....
VR package with the PD blower looks better to me, but I’m a PD blower fan so I might be biased. Lol. That said, getting the forged pistons put in at the same time is a good call.
Heck I'd pick the big bore and injectors over LT and off-road pipes (sill would go with CA front cat deletes). You can always bolt in headers, but the forged engine/cam is a one shot deal. |
Not needed, I did it anyway for grins...
ARP studs and imo I’d use a stock zl1 clutch and save like 1500 bucks, depending if you intend to drag it. Your build similar to mine.
SO, what do you think? D1X stage II, helical, race valve PP ported heads PP CAM w/ ARP studs, cometic gasket, and johnson lifters 2" LT headers w/ offroad pipes drop-in piston/rods Big bore lingenfelter pump LT4 injectors, in-tank AUX lowside kit ZL1 clutch. yeah unless i go meth&e85 and go big, I should be good with the ZL1 clutch. That should be right within my budget $20~$22K. Either this or i'm gonna find a build around Magnuson 2650 if I can find a killer deal. Would love to go to VR for that, but just too darn expensive. Where do you think this will put me power wise? I'm all about making power safely. |
Push rods, trunions, I went with Manley valves cause I’m paranoid. Power is pulley and rpm dependent. I’m tuned for a 4.0, 4.5 at 7000 rpm is 8psi. Had a 3.85 on which was stupid traction wise, calcs show 3.65 is about 90% on wheel speed at 7000 rpm near 1000 engine hp. 700 to 750 wheel hp is about the octane limit IMO on 11.5 cr. My first build was spec at 707 whp, this build with stock exhaust is about the same 707 wheel, 4.5 pulley on 93. I picked the cam for sound, to use the cam it would need 10.5 cr. Rough guess E85, lt, big injectors, dunno 800 wheel. U are limited both by cr and high side to 700 / 750 wheel, I call it all 707 wheel.
It has been my opinion that 800 and above engine HP builds should use heavy I beam rods and heavy forged pistons, rebalance crank or new crank with radius journals like the Lt4, main studs and 10.5 cr. |
