CAMARO6 (https://www.camaro6.com/forums/index.php)
-   Transmissions (https://www.camaro6.com/forums/forumdisplay.php?f=253)
-   -   Diff fluid setvice (https://www.camaro6.com/forums/showthread.php?t=491861)
bill496 04-18-2017 09:34 AM
Diff fluid setvice
Change your diff fluid at 1k, mine was filled with metal flakes on both magnets used royal purple 75w 90w
bill496 04-20-2017 09:04 AM
Do not drive in track mode all the time works the clutches hard
Sunsnare98 04-29-2017 06:17 PM
This is bs... track mode has nothing to do with the clutch.
My87z28 04-29-2017 07:58 PM
Unless you have a ZL1 or 1LE with the e-LSD then that would be impossible.
Hyperlinkblue 05-11-2017 02:19 PM
Really? Because the 2ss has the e diff too.
My87z28 05-11-2017 10:33 PM
No it does not. Only the 1LE and ZL1 received the e-LSD. The 1SS and 2SS have the exact same IRS. Example, the 1LE nor ZL1 axles will fit a 1SS or 2SS. However, the 1SS and 2SS axles are the exact same part number.
TJay74 05-12-2017 08:40 AM
Only the 1LE and ZL1 get the eLSD in the Camaro platform. Also the eLSD is active and works in all modes. You can see the power distribution in the performance screen.
Dmaxcc6spd 05-16-2017 10:12 AM
As for maintenance, there seems to be some confusion. Are there 2 fluids for the eLSD? The "normal" differential gears lubricant and the fluid the operated the eLSD?
What is the maintenance interval for the eLSD actuation fluid and what fluid is to be used?
Mr. Meh 05-16-2017 12:03 PM
Only the Coupe ZL1 and V8 1LE.
Vert ZL1s and V6 1LE don't get eLSD.
Mr. Meh 05-16-2017 12:05 PM
Correct. There are two different fluids. The clutch system on the driver's side in its own sealed housing and the regular old diff housing with gear oil.
I don't have that handy with me.
HOST1LE_gen6 05-16-2017 12:36 PM
1 Attachment(s)
I did mine yesterday. The interval should be in the manual along with the fluid but I have the fluid number handy
Update: manual says after the run in service. Every 45k miles
Doug kj6aco 01-13-2018 11:26 PM
2 Attachment(s)
Changed my diff fluid today with the above fluid right out of manual.
The only thing is the fluid is vary thin, I know it contains LSD modifier, maybe that thins it out.
I have 20,000 miles on it just 8 months, I have barked the tires going into 2nd and third but mostly freeway driving.
Small amount of silt a few pieces, normal ware.
