ZL1 1LE Transmission?
I'm ordering a neat piece from blueprint art, and don't know what transmission type is used in the ZL1 1LE. I know the Tremec is used in the standard ZL1 coupe, just can't seem to find the anything on the 1LE.
https://preview.ibb.co/bvOCW5/blueprint_art.png |
Its Tremec 6060 trans with different gearing is all, love the print.
What is interesting is the blueprint is supposed to be for the ZL1 1LE but then in the lower right corner they list the 10-speed automatic gear ratios. The ZL1 1LE doesn't come with an automatic. Only a manual.
Was hoping I could find the 2018 version of this..
http://www.gmpowertrain.com/assets/d...tion-Guide.pdf I think it's MH3 in the 1LE and the MJK is in the non-1LE for the TR-6060.. Though, if that's the case, interestingly, the 2017 CT6 with the LTG also has an MH3 coded TR-6060 transmission. Whereas the MJK one is only in the ZL1 Camaro. |
1 Attachment(s)
Here you go 2 gear seats from tremec, look at the last two you have E set.
Which is the rounded up MH3 from the PDF I linked. They just showed it to 3 decimal places in the other PDF.
Seems the A10 was in the plans right from the beginning. The 1st A10s were produced in May 2017 |
