New RS Tires
I want new summer tires and I kinda want a wider tire too and I want to know if yall have any recommendations.
245/40ZR20 has a 27.7" diameter and 255/40ZR20 has a 28" diameter. That is about a 1% difference so it shouldn't be a problem to run the 255. I don't believe anybody specs a tire wider than a 255 for an 8.5" wide wheel.
The bigger question is what are your driving habits and what is your budget. Web sites like TireRack.com will allow you to compare tires and read the reviews to help you find a tire within your budget that meets your needs. |
If the car is your daily, I'd avoid most summer/max performance type tires. You don't see any actual benefit until you're driving at 10/10ths, but you see all the negatives when you're just cruising around. Negatives being that summer/max tires aren't meant to be driven on when it's less than 50 degrees outside. My SS Sedan with Bridgestone RE050's is a complete handful on chilly days, and any decent rain is a no-go as well. I had the Michelin PSS & PS2's on my CTS-V coupe, both were like driving on hockey pucks under 50 degrees with the same terrible rain driving characteristics. On that car I eventually upgraded to the Michelin A/S3's which provide about 90% of the grip of the PS2's in warm/dry conditions, and about 500% better grip in colder/wet conditions. I would very highly recommend the Michelin A/S3's. They are expensive, but have been completely worth it. I guess my main point is to just be honest with yourself about the type of driving you're going to do. If you need a set of summer/max performance tires, then by all means, go for it! |
My 2 cents....
I went through the same exact issue and had every little response or help.
Do your own research and call respectable tire shops. I ended up with Continental Extreme Contact DWS 06 tires, (245/40/R20) I also looked at many others. (toyo, general, bf-goodrich, and michelin's) Best of luck to you. EagleRS |
I'm running 255/40's. Only a slight rub on my splash guard that came loose to fix while going over bumps.
https://i.imgur.com/8qnhIgo.jpg |
