ROTOR RINGS
since it appears dba is out of stock on rotor rings anybody use the girodisc ones on their ss/1le with the bbk? i have the zzp kit on my car and am going to replace the rotors next year and was looking at oem replacement vs rotor rings and saw these but couldnt find much info on here about them
also anybody try out the girodisc pads? only see front option tho so not sure what people are using on the rears? |
Do you have a link to what your looking at?
Rotors
Hey, back in my racing days, we used Coleman Race Products a lot for the friction rings. You can send them what you need and they will make it for you. Back in the day they were very fair with their pricing. Hope that helps....
I just talked to Ken about this last week. I am replacing my dba's after this weekend at Sebring. He says folks are very happy with the Girodisc. I'm going to get a set since he has them on the shelf. You also have to get the hardware kit, but can re-use the OEM hat. Side note...if you buy a set of the OEM rotors, you get rings and hats. I did that a couple of years ago to have a spare set trackside. I now rotate between the ring sets. |
yea im trying to figure out if i want to buy new rotors or just rings my price is about the same as i have a hookup on pricing...think im gonna go back to oem gm brembo pads for now until i get my 19s and 3rs the hawk dtc60 are too agrressive for the supercar 3s
Never heard of being able to use OEM hats with Gyrodisc rings The hardware kit comes along with the rings |
https://knsbrakes.com/c/car-item/496...or+Hats+-+PAIR
GiroDisc Replacement Rotor Rings - Pair - Slotted - Ring Only - Direct replacement for your OEM rotor rings. - Hardware is NOT included - please order separately. |
I went with the Gyrodisc front kit rotor and hat for ZL1 1LE |
im actually a ss owner with a zzp bbk but its the oem 1le rotors haha |
I have the Giro Disc rings. They work just fine but I'll not be buying another set. I bought them because DBA was out and the stock discs were up to $425+. In retrospect I will be buying a stock replacement set next go around. Two issues I have with the Giro Disc rings which may or may not be an issue with others are due to the slotting.
1. The slots create ever so slight pedal feedback so it makes it harder to get crystal clear feedback. Its just different and they work well (see #2) but I prefer the pedal feel on the solid face discs 2. The slots work very well in creating a fresh pad surface but it cost me 1/3-1/5 (track dependent) of the pad life and I'm not getting that back in braking performance so I just increased my consumable costs... |
I've used both DBA and Girodisc.
if the price was the same would you guys do the gyrodisc ones again or just buy full oem rotors?
