Will I need a tune?
Will I need a tune if I install a ported IM and TB or would I be fine to drive around without one?
depends on how your car takes the ported tb.
You will be fine.
I ran my Pray ported stock IM/TB and Rotofab setup on stock tune with no issues.
Thanks for the replies! I recently purchased a Pray Ported IM and TB from a member on here and really wanted to install the same day but thought I'd ask in case someone ran into some issues.
I know what I'll be doing this afternoon! |
I assume a bigger TB would require a tune. Does the LT2 IM fit? I am so out of touch! |
Usually yes, and depending on size an adapter. Yes it fits, with modifications. GPI sells one with the modifications already done and the MAP extension so you can just bolt right in. |
There is a section in this forum that is specifically for "bolt-on" discussion and all of this has or is currently being discussed. Power gains and Dyno charts are all in that thread.
