Protection after ceramic coating
I'm coming from using Zaino on my '02 Firehawk. That was the stuff to use back in '02-ish. So when I got my 2011 Camaro, I used it on that car too and got great results. On my 2018 1LE, I want to ceramic coat the paint with CQuartz. I've been doing lots of reading and have decided on using CarPro products for the most part.
However, I'm confused about protecting the surface after I've got the ceramic coating on it. Does it just need a sealant at that point (Reload for example), or is there more to it? My car is a daily driver (though I don't actually drive it every day) that will be exposed to Chicago winters. I'm sure I won't be able to re-apply Reload during the winter as I can't even wash the car most of that season. Also, this forum needs stickies with general info. It seems like the same questions get asked over and over in thread after thread. |
my car is ceramic coated and kept outside i wash it about every week or two and go back every year for my annual maintanence and it has been great! used quick detailer in between washes if i want to and thats all you gotta do no wax or anything
You should really top it with something like Reload, that is what gives it the gloss and extra boost/protection...basically it was originally created to be a ceramic coating topper.
3 Attachment(s)
This is what I use on my ceramic coating and as a quick detailer between washes.
It smells like bubble gum and makes my car's finish super slick. It can be found at www.shopatpcs.com along with other products to help keep your vehicle's ceramic coat intact. Win, win in my book. :thumbup: |
^^Car looks great!! Can't tell from the pics, but have you thought about painting the calipers the same green or red?
My suggestions: 1. Avoid getting acidic water on the car (Don't park under trees). 2. Avoid letting any kind of water dry on the car if at all possible (not realistic with a DD). 3. Put a good durable hydrophobic coating (Gtechniq EXO) on top of the ceramic (can be done DIY). 4. Religious use of non-durable sealants like Reload will help resist water spots. 5. If you do use something like EXO, then dilute one part of Reload into five parts distilled water to avoid the Reload streaking. |
1 Attachment(s)
I use CQuartz UK ceramic on my car. I actually topped it with Chemical Guys Pete's 53 Black Pearl carnuba was and it looked killer. Also used McKees 37 high def paint sealant on top. However, reload is made to be the topper of choice by Carpro.
2 Attachment(s)
I thought about it, but with the stripes on my rims I figured that was enough green and I'm getting rid of my red taillights for smoked, sequential ones so I saw no need for red calipers either. Here's a nice, shiny picture of my car after it was hit with the ceramic quick detailer I use. The guy who did my ceramic coat recommended the quick detailer and it smells like bubblegum so it's definitely a win win. |
