FS: 2017 Camaro SS 50th Anniversary Edition (RPM BUILT)
50th Anniversary Edition Camaro. Built Motor (Race Proven Motorsports Stage IV Package.)
RPM Custom LT1 DOD Delete Camshaft Package (Includes - RPM Custom Spec’d Comp Cam w/ Increased Fuel Flow Lobe, Brian Tooley Racing Dual Valve Spring Kit, Brian Tooley Racing 3/8" Hardened Pushrods, ARP Head Stud Kit, Katech C5R Timing Chain, GM LS7 Lifters w/ GM Lifter Trays, GM MLS Cylinder Head Gaskets, Katech Valley Cover, ARP Head Stud Kit, Comp Phaser Limiter, GM VVT Cam Bolt, GM Crank Bolt, GM LS Front Pulley Seal, GM LT Water Pump Gaskets, GM RTV Sealant Advanced Inductions Ported and Polished LT1 Cylinder Heads Billet Thermostat Housing w/ 160 Degree Thermostat Whipple Supercharger System Whipple 3.250" 10 Rib Supercharger Pulley Supercharger Whipple Supercharger ProMeth Methanol System w/ Stainless Steel Lines, Standard 3 Gallon Tank, Dual Nozzles, Snow Solenoid and AEM Controller RPM Custom Fuel System w/ Holley Fuel Pump, Holley In-Line Fuel Filters, Holley Fuel Pressure Regulator, GM Flex Fuel Sensor, AN Fittings, and Aeroquip Hose. E85 Fuel Brian Tooley Racing Diamond "Drop-In" LT1 Piston/Rod Set GM Connecting Rod GM 6.2L LT1/LT4 Head Gasket Katech Valve Covers w/ Custom Powder Coat Katech Coil Re-Location Kit Katech Spark Plug Wires Torque Converter 8L90 Pro Series Stage III 258mm 1A s/n:A-4301 https://www.youtube.com/watch?v=ifwO...o9_Xx&index=13 On Dyno 4:06 into the video at RPM. $52,000 OBO |
Quite a hardcore F1FTY, good luck with sale :thumbsup:
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
