Ported throttle body with gm tune??
Hey guys,
Was wondering if anyone on here has the gm performance cold air intake and the gm tune on their camaro. I was debating adding a ported throttle body but I am unsure how it will affect air fuel ratio and drivability with the gm performance tune. thanks guys |
You can do following without needing a tune (obviously tune would yield more power)
Ported Throttle Body Cold Air Intake Catback Exhaust Secondary Cat Delete If you want to add Intake Manifold you will need to tune the car. |
I totally understand as this isn’t my first rodeo. However the car I purchased has a gm performance cold air intake and the gm performance tune.
I’m just curious as to how the gm performance tune would cooperate with the ported throttle body |
I have a 2016 2SS with the GM CAI and tune. Later I added a Mamo ported throttle body and finally I added a Pray ported intake manifold a few months ago. I don't have an easy way to check AFR but the car has run fine with no CELs or problems with any of these combinations. I hope this helps.
I have about 4K miles on GM CAI/GM tune and Tony Mamo ported throttle body with no issues. Combo works well for me, got rid of a little bog I had noticed.
There is no blanket statement of “these mods don’t need a tune”
Fuel quality varies by region, as does the air, as does each brand of part Gaurantee like half the stock SS’s in the country will see some knock on 93 octane and pull a little timing, just because of the fuel quality by region. From a tuner that travels around the country - “Washington DC area has the best fuel, followed by philadelphia area” |
A ported throttle body is going to give throttle response vs HP and will not effect any fuel trims what so ever. Like GuywithL86 mentioned, every mod needs to have a calibration for max performance. Modding with no tune is not the brightest idea. These LTs are not like the LS where you can get away with being a little more rich.
I was going to make a thread about this and then decide to use my noodle a utilize the search feature. I'm in the same predicament, have the gm cai with tune and want a ported TB. Seems like it should be fine, has anything verified since? OP?
Add ported OEM IM to that list. Only need a tune for larger than OEM TB or MSD IM. |
Yup all good. Added tony Mamo ported tb a while back. Nothing but praise. Really improved the drive ability. Totally worth it.
Tb
