Crash upgrade help
Hi all
I had a mishap in my new 2017 2LT RS convertible. Smashed in the front end��. While in for repairs I’d like to add some of the aero kit pieces and wanted to know what would fit. Specifically I love the look of the ZL1 side skirts. Does anyone know if the ZL1 sideskirts will bolt on to my 2 LT? And/or what additional parts I’d need to add them? The bodies of both cars appear identical but you never know. I’m only interested in OEM GM parts by the way. Thanks for any help! |
I believe only the entire front fascia and side front fendors are wider. The rest of the body should be the same.
Those are aftermarket skirts in the video.
Has anyone ever installed the OEM GM ZL1 skirts on one of the other models... I’d like to do so on my 2LT. The parts dealer at my local Chevy dealer says they probably won’t fit (but couldn’t bother to look up any surrounding parts for cross reference. The guy in the body shop of he same Chevy dealer says he thinks they should bolt up no problem (but has never tried or seen it done). The difference between the ZL1 side skirts and the aero kits for the other models is that all the aero kits bolt ON TO THE ROCKER PANELS whereas the ZL1 side skirts are a molded on PART OF THE ROCKER PANEL. So to install the OEM ZL1 side skirts you must remove your stock rocker panels and replace them with the ZL1 rocker panels (which have the side skirts molded into them) If no one can confirm they have done this and it bolts on then I suppose I’ll buy just one side and experiment for myself. This may be an expensive experiment if this doesn’t work�� |
Someone on here put ZL1 skirts on his SS. He pulled the bottom of the fender out at the rear of the front wheelwell.
:thanks:
All cars EXCEPT the ZL1, and ZL1 1LE, are the same width. The ZL1 has wider fenders, bumper and side skirts to accommodate the width. If you want real OEM ZL1 side skirts, you will have to order the entire rocker. |
The ZL1 side skirts are part of the rocker I believe... molded as one piece
I’m trying to figure out what else I need to change to mount them |
Can you be more specific about what needs to be addressed...
Is it just that the skirt sticks out farther than the fender at the very bottom front? If so perhaps the fender stone guards could fill in the gap or some other mud flap sort of thing If that’s all it is I can make something easily Or Does the entire bottom of the fender need to be spaced out from the front of the door forward? That might be a bit more involved |
The flare of the wheel arch is more significant. The bottom of the fender behind the tire is where this is pronounced. I imagine this can be addressed, and made to work without fenders, in fact I know it has been done, but I don’t feel comfortable telling you to go for it as nobody has taken pictures or written how they addressed the gap. |
http://www.camaro6.com/forums/showth...=488562&page=9 -Last page shows convertible mod. http://www.camaro6.com/forums/showthread.php?t=500230 -Shows how to fix the gap. |
Well I just ordered them so I guess I’ll be the guinea pig
Just to clarify, the ZL1 DOES NOT have wider fenders. They are the exact same fenders as the other trim levels. They are just pulled out further at the bottom behind the wheel via a longer brace. jp9109 above posted links earlier to the threads where someone bought ZL1 rockers and had to fix the gap due to his fenders not being pulled out like a ZL1. Link further up shows a vendor that makes ZL1 style rockers that works on non-ZL1 trim levels without adjusting the fenders.
