Foglight issue
1 Attachment(s)
Hello all,
I have noticed that the passenger side foglight on my 2022 2SS is considerably dimmer than the driver side. I know for a fact it was good when I got the car, but now after around 3000km it has gone dim. Any ideas? Has this happened to any of you? Also wondering if my full coverage warranty would cover this. Seems goofy that after only owning the car for 3 months I might need to dump $200 into a defective factory part. Any advice/ideas welcome. Cheers, James |
Its under warranty. 3 year 36,000 miles Bumper to Bumper.
That's your right side daytime running light. Not a fog light.
Should be covered under warranty. I would first suspect a connection problem. |
A connection issue is all the more likely because these have two modes, dim and full bright, so it could be stuck in the former due to a wiring harness or connector failure.
Take the car in and let the service department figure it out (make sure they know you care about the paint on your bumper, so they should, too, when removing it). |
Awesome, thanks guys!
I’ll make sure and get that taken care of next time I take it in. Cheers |
