Wiring CCFL Halos question?
So I installed a set of CCFL halos yesterday and they look fantasic. Only issue, nit pick of mine is I want the actual halo part to stay on during the day when the lights are off. But since we spliced them to the side markers' wires, they only turn on when the actual lights turn on. Is there another place we could wire them to have power so they are on day or night? Thanks in advance.
If you want them on whenever the car is on, then use the underhood fuse box. F8 should work. Just need an add-a-fuse.
what size wire gauge and where do u tap the ground wire
