Boost Question
Just looking for some input, this is my first turbo setup. It is a single front mount setup, currently running 9psi. Under full boost, I’m getting a popping sound, like a backfire, especially under WOT. Any ideas where to start? Mods are as follows.
-LY6 Iron block 6.0L, Mahle rings gapped for boost -15W40 Rotella Oil -LS3 heads, mildly worked for boost (opened exhaust port). -TSP .660 springs -Cam motion Turbo camshaft - 228/224 115. -ARP head bolts, LS9 7-layer head gaskets -Melling high volume oil pump -C5R timing chain -TR6 plugs gapped at .28 I believe -Stock LS3 intake, ported stock 90mm TB -1000cc injectors, ZL1 intake fuel pump, DSX Aux pump -Comp Turbo 67mm -Turbo Smart E40 boost controller -Autometer wideband -Tial wastegate/BOV - 3” Exhaust |
Check the plugs, make sure the wires aren't burnt. Drive mildly and refill with top tier fuel (Shell, Exxon, BP). See if that changes anything
Sent from my Pixel 4 XL using Tapatalk |
