Ported and polished intake manifold
8 Attachment(s)
Am halfway done porting and polishing my intake manifold, from the entrance of the 80mm throttle body, the the full length of the runners on the inside, to the metal lower intake. The metal piece has been polished to a mirror finish, and has come from 3.9mm to just under 4.5mm. The plastic runners I also managed to polish up pretty well, they're nice and smooth again but noticably wider. I also posted pics of the metal piece just rotated, so you can see just how much meat I was able to get from both the runners inside and the metal itself. I also have the LLT engine, so my ports are O shaped rather than D shaped, which was much easier to work with. Still need to finish up the entrance, and then do the other half of the manifold but it's coming along pretty nice
The pictures look like the plastic and metal meet pretty unevenly, but they're actually matched up almost exactly. Just looks funky because the black plastic is reflecting off the mirror finish of the metal
I had my intake and 80mm TB ported at Air Flow Solutions. Bret did a full porting; cut it open and ported all throughout. It made a hell of a difference. Throttle response is through the roof now. I love it.
If you don't have one, i'd recommend a spacer from MACE Engineering. They call them 'insulators.' I have the 25mm (1 inch) and with the porting done it gets a lot more air into the combustion chambers faster. I'm at, what i believe is the top of the ECM's learning curve with all the air going in without a tune. I also have the ACCEL Super Coils to give me more spark with all that air. Great to see others upgrading their LFX too. Sometimes i think i'm the only one doing it. |
Did the super coils make much difference? |
I've done a ton of work, what do you mean by super coils though?
Fortunately that isn't the case. |
1 Attachment(s)
Thanks, should go nice with my next project
This thread motivated me to pull my intake system apart and finally port my intake manifold to match my 80mm TB, since I had one from before the 80mm was an option. So thanks.
(Also, most people have a ton of issues with the Accel coils... you might get lucky if you try them, but the Delco ones are by no means bad) |
what exactly do people fill the oil gully in with? Maybe I'm paranoid but I worry that the oil will breakdown the epoxy eventually. I dont know if I want to justify $100 for the laminator piece. Maybe ill just port the first inch of the manifold to match the throttle body and clip the top turbulence part and leave the dip.
I forget what Jason uses for his ported LFX manifolds but it is fine and holds up to sanding as I have found out now. I've had one since they came out (6 years), no issues.
I used the highest strength steel epoxy I could find, was only 10 bucks or so. 900psi tensile strength, heat resistant to I think 250, cleaned and degreased the manifold real good first. It isn't coming out anytime soon, trust me. Now if you used something weaker and not high temp resistant, you'd have issues
